jobsmart welder at TSC
/ jobsmart welder at TSC #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
I see tsc has a lil flux welder on sale for 99$ or fathers day.
anyone got one of these?
99$ is darn cheap.
I have a lil 70a stick i do sheet metal with and a big crackerbox for the thick stuff.
had always though of toying around with a lil wire feed welder for prettier sheet metal work.
next question.. anyone make aluminum flux core wire ( that's what i wouldn't mind is welding aluminum. i know you can get stick electrodes for aluminum.. but i think they are dc only... )
opinions..
soundguy
/ jobsmart welder at TSC #2
I've never had success welding thin material with flux wire--too easy to burn through. If you're going to do sheet metal, you'll be much happier with solid wire and shielding gas.
/ jobsmart welder at TSC #3
Have no idea about that particular welder, but look at the output of the welder to verify that it is a DC output welder if you are even remotely considering it.
As you already know by your Stickmate, Stick welding is fine with AC power if you use the appropiate rods that are designed for AC. However, all flux core wire feed wire is designed for DC so why Harbor Freight and others would make the cheap wire feeders have an AC output is not really a good idea except for price - but it will never work well. I am not against a cheap welder or even Harbor Freight as I shop there, but I absolutely would not buy an AC output wire feeder.
That said, I run Flux core in my little Lincoln 115 volt wire feeder and like flux core as I do most all of my welding outside. Welding outside with Mig using shielding gas does not work well - wind blows the gas away.
/ jobsmart welder at TSC #4
I also seen that and thought it was reasonable. You need a spoolgun to do aluminum well. You will have all kinds of problems otherwise trying to feed that soft wire. You will also need more then a 110v machine.
/ jobsmart welder at TSC #5
Why?
I'm not aware of flux core aluminum wire. I'm sure there's areason it's not made, though I don't know what it is. Could be that the flux would cause impurities? Sure would be nice if it worked.
I don't think i've ever seen a wire welder that wasn't DC ??
as for getting a huge mig with bottles setup.
not gonna happen.
If the lil flux welder was gonna be better tat welding 18 ga to 1/8 better (easier) than my lil 30/70a stick welder.. for 100$ I'd pick it up.
if it's not better.. I can keep using the small stick. been welding sheet metal with it for 10 ys now...
can't justify the cost of a full mig setup... there are 40 thousand other tools I need first ahead of a full mig setup.
soundguy
/ jobsmart welder at TSC #8
I don't think i've ever seen a wire welder that wasn't DC ??.....
soundguy
Well most of them are, and absolutely all of them should be! That said, when the price gets really cheap you need to be very careful. See this thread and make sure you read the whole thing as there are many posters who even posted the wrong info within the thread based on their preconceived assumptions that it is already DC simply because it is a wire feeder - look at the pic in post #16 which even clearly shows the dataplate indicating an AC output wire feeder.
It is comical to see some of the posters who have actually posted pics in other threads showing their welds with an AC output wirefeeder - Yuck. An AC wire feeder will simply never work well because all the wire is designed for DC. The level of Spatter is ridiculous.
In this case, I am not trying to pick on Harbor Freight as I like some of their stuff, but there are much better choices in the low cost realm of wire feeders than a POS like this one.
If the TSC welder is a DC output welder then it is a relative bargain for the price - simply look at the dataplate on the machine and it should tell the tale.
Converting 90 amp AC welder to DC - WeldingWeb - Welding forum for pros and enthusiasts
will go take a look this weekend and post back.
simply can't imagine an ac wire welder....
soudnguy
/ jobsmart welder at TSC #10
Some of the smaller welders basically have two power settings and maybe 4 wire speed settings. Flux core burns hotter than solid wire. That's why flux core isn't a good choice for sheet metal. The other thing about smaller migs is the limited duty cycle. I don't know if this particular unit allows you to use gas with it or not.
I blew a couple of hundred on a small HF mig and then went to the Hobart 187. I would have saved money and done better welding if I just bought the 187, a Lincoln or a Miller to start with.
I just don't need one bad enough to drop over 100-120$.. past that I can use my 30/70a stick and 1/16 rods.. BTDT
/ jobsmart welder at TSC #12
A competent stick welder really might not see much value in a mig especially if very little work is being done with thin material. IMO, such a person isn't likely to be satisfied with a cheap mig.
so far all my sheet metal work has been done satisfactorilly with a 1/16 rod on a 30a setting on a lil stick .. are you saying that a 110 flux job won't make any prettier bead or any less chance of a burn thru thn the stick? ( honestly don't know as I've only used big migs.. no small flux jobs.. )
soundguy
/ jobsmart welder at TSC #14
IMO, commonly available flux wire is just not good for welding sheet metal. There apparently used to be a specialty 20 gauge flux wire that these guys say was good, but apparently you can't get it any more:
flux cored welding wire
The other issue is your control over the heat settings with a smaller mig. The larger ones have multiple heat settings--the smaller migs tend to have two and good luck if either one happens to be the right one for the sheet metal you're trying to weld.
2025 24in Bucket Mini Excavator Attachment (A66734)
2025 24in Bucket...
2008 GENIE Z-45/25 TELESCOPIC BOOM LIFT (A65056)
2008 GENIE Z-45/25...
GENERAC MOBILE PRODUCTS MLT6S LIGHT PLANT (A67714)
GENERAC MOBILE...
2021 DITCH WITCH HX30G VACUUM TRAILER (A63276)
2021 DITCH WITCH...
Generator (A64553)
Generator (A64553)
Jeep Metal Tailgate Metal Decorative Sign (A66738)
Jeep Metal...
