Jinma Instrument Cluster Help
/ Jinma Instrument Cluster Help #1
dhelvey
Wenatchee, Wa
Jinma 284
I recently purchased a 2006 Jinma 284 with the old rectangular instrument cluster. The tach does not work and other gauges work intermittently. I am interested in purchasing and installing a new instrument cluster and wondered if anyone had done this and if they would share the wiring schematic of the old and new style instrument clusters.
Thank you,
Dave
/ Jinma Instrument Cluster Help #2
If your gauges work intermittently I suspect you have a grounding issue somewhere. A power supply issue is also possible but grounding is probably more likely.
/ Jinma Instrument Cluster Help #4
Behind the dash is a favorite habitat for furry little creatures. They eat the insulation and can actually sever copper wires. That would be my first place to look for nonfunctioning/intermittent gages. Do that before buying a new panel.
/ Jinma Instrument Cluster Help #5
The Jinma tach sensor often fails. It's a simple replacement. There's been a lot of discussion over the years.
SCAN TO RECEIVE TEXT UPDATES (A65053)
SCAN TO RECEIVE...
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A65643)
2015 VANTAGE...
2016 P.J. Deck Over Trailer, VIN # 4P5F82028G1250354 (A65563)
2016 P.J. Deck...
2023 New Holland C327 High Flow Compact Track Loader Skid Steer (A64553)
2023 New Holland...
Landhonor 8' x 6' Metal Shed (A66408)
Landhonor 8' x 6'...
1996 Aspen T/A Pump Trailer (A64194)
1996 Aspen T/A...
