Loader JD210LE - PTO addition?
/ JD210LE - PTO addition? #1
edkemper
Klamath Falls, Oregon
JD 210LE, Case 580CK Series B Backhoe, 1991 WoodMizer LT40 Log Mill, 1989 JD450E Crawler Tractor, FordsonMajorDiesel
Is there a PTO kit for my JD210LE?
If I remember correctly, it was an option? So I'd think I could add it to mine.
Any help or direction?
/ JD210LE - PTO addition? #2
Ed,
I would write down the full model and serial number and stop by the industrial JD dealer. Ask if there is a "whole goods" pto kit option. Also ask the parts department about this. I would not expect to see a generic offering anywhere else. There are a few serial number breaks in the 210LE and different options that might make a difference whether you can do this. Just have to ask the dealer to get a handle on it, may find it is reasonable or prohibitive.
That is why I suggested the hydraulic auger set up. Better than a pto type without reverse that can get the bit stuck. This would work on future large tractors as well as the 210. I have the PA30 on my 110 backhoe and it will make quick work of post holes.
I also mentioned taking the add on money and trading up for a 210 with the pto option if you can find one in your budget.
I would explore all of these options before putting any money down.
/ JD210LE - PTO addition? #3
Is cost prohibitive, there is just too many items involved. You are better off living w/out a pto or finding a machine that already has. Good luck
Just got a call back from the dealer. He said he was already up to about 10K and wanted to check and see if I wanted hm to continue. We agreed that another PTO tractor was a better choice.
New/Unused Wolverine 78in Quick Attach Land Leveler (A65583)
New/Unused...
PORTER CABLE AIR COMPRESSOR (A65643)
PORTER CABLE AIR...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
12ft T/A Utility Trailer (A64557)
12ft T/A Utility...
2025 MACK GRANITE GR64F DUMP TRUCK (A63276)
2025 MACK GRANITE...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
