JD valve stem size
/ JD valve stem size #1
defed
WNY, USA
i'm getting ready to change front tires on my JD 4300. i know (well, think) that there are 2 common valve stem sizes, .453" diameter hole and .625". i could tell they aren't the bigger one, so i got the .453". now that i have them in my hand, the .453" look bigger than what's in the wheel. not sure i can get a good measurement, and it's too late when i cut the old ones off! i see there is a .346" diameter stem, but seems to be uncommon. does anyone know if deere used the common size of .453" (11.5mm) or if it's smaller?
after i got the tire off, the stems were stamped. They were .453"....but i swear they look smaller.
/ JD valve stem size #3
It doesn't make sense, the holes do caliper out different that the numbers they give, but that's what they're listed as. I have the big ones because Datsun used them on the pickup wheels for some reason.
after i got the tire off, i saw mine were stamped tr413, so then i knew it was .453"...i got tr412 (.453") because I knew it wasn't the .625" (tr415 are) but when i compared the tr412 to the ones in the rim, it just looked smaller, that's why i was wondering if they were oddball and a smaller size. i never did check the actual hole size since the 'specs' said they were the same diameter (and they did go in).
Sullair 185DPQ 100psi Towable Air Compressor (A61572)
Sullair 185DPQ...
FUEL TRANSFER TANK (A63569)
FUEL TRANSFER TANK...
Rogator RG1100 (A63688)
Rogator RG1100...
2020 Ditch Witch SK1550 Stand on Skid Steer (A64047)
2020 Ditch Witch...
2015 Nissan Frontier 4x4 Crew Cab Pickup Truck (A61573)
2015 Nissan...
2007 INTERNATIONAL PAYSTAR 5600 Bucket Truck (A62679)
2007 INTERNATIONAL...
