JD valve stem size
/ JD valve stem size #1
defed
Gold Member
WNY, USA
i'm getting ready to change front tires on my JD 4300. i know (well, think) that there are 2 common valve stem sizes, .453" diameter hole and .625". i could tell they aren't the bigger one, so i got the .453". now that i have them in my hand, the .453" look bigger than what's in the wheel. not sure i can get a good measurement, and it's too late when i cut the old ones off! i see there is a .346" diameter stem, but seems to be uncommon. does anyone know if deere used the common size of .453" (11.5mm) or if it's smaller?
after i got the tire off, the stems were stamped. They were .453"....but i swear they look smaller.
/ JD valve stem size #3
It doesn't make sense, the holes do caliper out different that the numbers they give, but that's what they're listed as. I have the big ones because Datsun used them on the pickup wheels for some reason.
after i got the tire off, i saw mine were stamped tr413, so then i knew it was .453"...i got tr412 (.453") because I knew it wasn't the .625" (tr415 are) but when i compared the tr412 to the ones in the rim, it just looked smaller, that's why i was wondering if they were oddball and a smaller size. i never did check the actual hole size since the 'specs' said they were the same diameter (and they did go in).
2016 SMITHCO SMQ-45-001 SAND STAR (A66091)
2016 SMITHCO...
2014 Ford Escape SUV (A66738)
2014 Ford Escape...
SARLO (A64557)
SARLO (A64557)
2011 UNKNOWN FRAC PUMP (A67714)
2011 UNKNOWN FRAC...
2019 JCB 409-T4 WHEEL LOADER (A65056)
2019 JCB 409-T4...
DITCH WITCH 3700 TRENCHER (INOPERABLE) (A67714)
DITCH WITCH 3700...
