JD 4400 Tractor won't start
   / JD 4400 Tractor won't start
Beenthere and K7LN,
Does the tech manual have physical descriptions of the various relay and switches? And does it describe how to pull the instrument panel to get at them? At this point, I'm limited to physically tracing the wiring to find and test the various relay and switches.
Also, the schematics that you all provided does seem to match what I'm seeing. For example, the ignition switch has three red, one green and one white wire. The schematic doesn't show the white wire.
I really appreciate everyone's help...kept me from pulling the starter and taking it in.
   / JD 4400 Tractor won't start #22
doc
There is a relay test procedure, and I suspect it applies to the relays in the fuse and relay load center. The relay is K2 that is the starter relay.
   / JD 4400 Tractor won't start #23
I don't have any manual. I'm just going by what was posted earlier. Rather than test the relay, just swap it out with another one or use the spares in K10 & K11 if you have them. I think they will all be the same.
You might want to try and place a jumper from F5 straight to the solenoid. If things work then, you've narrowed the problem area down to the switches and connections in that part of the circuit. You can also pull K2 and place a jumper between pins 30 & 87. That will take K2 and the rest of the circuit out of the picture.
As to the white wire, it's not shown because it belongs to an unrelated circuit.
Not to try to confuse things, but a bad ground on relay K2 would also stop it from cranking.
   / JD 4400 Tractor won't start #24
That's true, you can never dismiss ground problems. What makes it hard is that you don't know what the guy on the other hand has for experience and tools. Furthermore, the schematic makes it look easy, but where the parts are actually located is a different story.
Trust me, I know. I'm doing the same thing on a JD2240 and the manual that came with it was the wrong one. Totally different wiring schematic from what the tractor has for wiring. Buying a new manual's out of the budget right now so I'm in the same boat that he is, other that I'm an electrician by trade for thirty years and did electronics in the Marine Corps and now work as a traffic Signal technition. Lots of practice troubleshooting electrical circuits.
   / JD 4400 Tractor won't start #25
I am not familiar enough with other tractors to know if the 4400 is similar to my JD 4500 or not. On my 4500, the PTO is activated with a dash pullout switch and every once in awhile I have to TURN the knob slightly in order to get interlock continuity for it to crank. (You can tell when you turn the key to ON and do not hear the fuel solenoid click.)
Obviously, the PTO switch on mine has a problem, but I choose to ignore it for now as I know what it wants: turn a bit while it is only a push/pull activated switch to get interlock continuity.
If you have a pull out PTO switch, try turning the knob a bit CW and/or CCW.
   / JD 4400 Tractor won't start #26
I am not familiar enough with other tractors to know if the 4400 is similar to my JD 4500 or not. ..........
The 4200, 4300, and 4400 are on the same size frame. The 4500 -4700 are on a larger size frame. Other than that, there are similarities (beyond the green paint :D ), but not the same layout.
Here's hoping doc finds his 4400 starting problem.
Hey guys,
Thanks again for the input. Not having a lot of luck due to inability to find the physical location of the F5 fuse and the PTO and transmission neutral switches on the wiring schematics. Tested the K2 relay which tested fine.
Probably have to get it trailered in to the local JD shop.
   / JD 4400 Tractor won't start #28
Hey guys,
Try making a jumper wire from pin 5 on the start switch to pin 86 on K2 start relay. This will bypass the safety switches and test the fuse when trying to start it. If it starts, the problem is in one of the safety switches...if not, it's the fuse.
Scratch that...that would test fuse F1.
I'm sure someone can tell you where those parts are.
   / JD 4400 Tractor won't start #29
Hey guys,
Doc, did you try turning the PTO knob a bit, assuming yous has one?
Arrgh...JD can't get to it for two weeks and I've already lost the 5yr old boy in the tall grass.
Anyone have any information on where to physically locate the F5 fuse, the rear PTO switch, and the neutral transmission switch?
Thanks again everyone.
2018 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A55852)
2018 Chevrolet...
Toro Multi Pro 5800 (A53424)
Toro Multi Pro...
2008 Ford Ranger Pickup Truck (A54814)
2008 Ford Ranger...
Cushman Electric Golf Cart (A55853)
Cushman Electric...
2017 Chevrolet Sonic Premier Sedan (A55853)
2017 Chevrolet...
2019 John Deere 210G Hydraulic Excavator (A55851)
2019 John Deere...
