JD 4010 Compact Utility Tractor
/ JD 4010 Compact Utility Tractor #1
mike8149
Does anyone know how the 3 point sway bar rod comes apart in the 4010? I would like to change the transmission fluid and filter but have to remove the rod in order to get to the filter etc. The rod appears to be in two pieces that removes from each side. Thanks, Mike
/ JD 4010 Compact Utility Tractor #3
It’s a one piece rod, but if I remember correctly, it will slide to the side into the rear wheel rim allowing you to get everything out of the way
/ JD 4010 Compact Utility Tractor #4
Yes rod key# 27 in the jd parts link, slides out of the key #25 parts, looks like to me.
/ JD 4010 Compact Utility Tractor #5
You may need to move it to the side, possibly near the rear wheel rim, to get clearance for the filter.
Thank you, I'll remove the lock pin on both sides and try sliding the rod to the left to see if it opens up enough space to access the filter cover
/ JD 4010 Compact Utility Tractor #9
On a related note… are those R-pins the only thing keeping the turnbuckle from rotating?
Looks like a waaaay simpler (and easier to use) method… trying to get a big ol’ wrench on my stabilizer bars is getting old…
/ JD 4010 Compact Utility Tractor #10
Yup, my '97 JD-770 has them also. I would get the largest pin to fit the hole tho as mine do bend a bit sometimes. If I remember, it mainly only seems to do it using my Sitrex cutter.
Lincoln Electric Shield-Arc SAE-400 - Radiator Missing - For Parts or Rebuild (A63689)
Lincoln Electric...
John Deere 660 Hay Rake (A66408)
John Deere 660 Hay...
76in. Low Side Skeleton Skid Steer Bucket (A65640)
76in. Low Side...
Rigging, Binding, Chain & Lifting Equipment (A66408)
Rigging, Binding...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A DAY CAB TRUCK TRACTOR (A59908)
2017 FREIGHTLINER...
60in Bucket Skid Steer Attachment (A61567)
60in Bucket Skid...
