JD 2305
/ JD 2305 #1
Wvanatti
John Deere 2305 (2010)
Gents,
I have a 2010 " 2305". I was mowing with it this morning when it suddenly died. The fuel gage dropped to zero. The tank is 3/4 full. I tried starting it and figured out it will stay running as long as I hold the key switch to start. I was able to drive it back to garage that way. Any ideas where a fuse would be blown and where to look ? Thanks in advance for imput.
/ JD 2305
Disregard, it was the fuse by the air breather (15a)
/ JD 2305 #3
Good to hear you found the problem.
Hope the starter is ok after making that trip back to the garage.
/ JD 2305
Completely my fault ! I had hooked up a trailer last fall and tied into the turn signals with a pigtail, the wire was pinched with the 3 point hitch causing a 20 a fuse to blow. For future reference for anyone ... The motor started back up but only ran when I held the key to on. I was able to let off the key switch gently till the starter quite turning. ( sound ). And drive it. To garage shade. Having my girl not run was a hopeless feeling. Whew - got lucky
/ JD 2305
All is right with the world :). For now....
Front Tank Bracket (A64127)
Front Tank Bracket...
New/Unused 72inch Quick Attach Rock Grapple Bucket (A65583)
New/Unused 72inch...
2013 INTERNATIONAL DURASTAR 4300 M7 SWEEPER TRUCK (A63276)
2013 INTERNATIONAL...
2011 FORD F-150 (A65643)
2011 FORD F-150...
2022 EZ-GO ELITE...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
