JD 2305
/ JD 2305 #1
Wvanatti
John Deere 2305 (2010)
Gents,
I have a 2010 " 2305". I was mowing with it this morning when it suddenly died. The fuel gage dropped to zero. The tank is 3/4 full. I tried starting it and figured out it will stay running as long as I hold the key switch to start. I was able to drive it back to garage that way. Any ideas where a fuse would be blown and where to look ? Thanks in advance for imput.
/ JD 2305
Disregard, it was the fuse by the air breather (15a)
/ JD 2305 #3
Good to hear you found the problem.
Hope the starter is ok after making that trip back to the garage.
/ JD 2305
Completely my fault ! I had hooked up a trailer last fall and tied into the turn signals with a pigtail, the wire was pinched with the 3 point hitch causing a 20 a fuse to blow. For future reference for anyone ... The motor started back up but only ran when I held the key to on. I was able to let off the key switch gently till the starter quite turning. ( sound ). And drive it. To garage shade. Having my girl not run was a hopeless feeling. Whew - got lucky
/ JD 2305
All is right with the world :). For now....
2006 Cadillac Superior 6-Door Limousine, Ultra-Low 20396 Miles (A63689)
2006 Cadillac...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2020 DRAGON ESP 150BBL ALUMINUM (A60736)
2020 DRAGON ESP...
3pt Hydraulic Log Splitter (A64127)
3pt Hydraulic Log...
DECKED TRUCK BED SLIDING TOOLBOX (A60432)
DECKED TRUCK BED...
Gehl RS5-19 (A62177)
