JD 2305
/ JD 2305 #1
Wvanatti
John Deere 2305 (2010)
Gents,
I have a 2010 " 2305". I was mowing with it this morning when it suddenly died. The fuel gage dropped to zero. The tank is 3/4 full. I tried starting it and figured out it will stay running as long as I hold the key switch to start. I was able to drive it back to garage that way. Any ideas where a fuse would be blown and where to look ? Thanks in advance for imput.
/ JD 2305
Disregard, it was the fuse by the air breather (15a)
/ JD 2305 #3
Good to hear you found the problem.
Hope the starter is ok after making that trip back to the garage.
/ JD 2305
Completely my fault ! I had hooked up a trailer last fall and tied into the turn signals with a pigtail, the wire was pinched with the 3 point hitch causing a 20 a fuse to blow. For future reference for anyone ... The motor started back up but only ran when I held the key to on. I was able to let off the key switch gently till the starter quite turning. ( sound ). And drive it. To garage shade. Having my girl not run was a hopeless feeling. Whew - got lucky
/ JD 2305
All is right with the world :). For now....
New 20'x20' All Steel Carport (A62679)
New 20'x20' All...
3269 (A63117)
3269 (A63117)
2023 Bobcat T770 (A64126)
2023 Bobcat T770...
2008 Kawasaki ZX1000 Motorcycle, VIN # JKAZXCE1X8A013733 (A65563)
2008 Kawasaki...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
Informational Lot - Shipping (A63688)
Informational Lot...
