JD 1020 power steering
   / JD 1020 power steering #161
Benedek
Happy Easter to you & all other members.
"L" is designed to be utilized for all ground engaging implements such as plows/disk harrows & allow tractor hyd mechanism to control 3 pt/implement height. "D" is designed for all other functions such as operating a mower or blade where operator desires to control height of 3 pt & attached implements. "L/D" is a less sensitive setting than "L".
Jim
PS: your last sentence is incorrect
Thanks, Tx JIm...
So I going to select the level D position and do my job... When, rarelly I going to plough, I repush in positon L...
Sincerelly, Benedek Joseph
Hi,
I have a new problem with a stering arm from the front axle as you can see on the attached short video.
The triangle shaped bellcrank is clicking very much on its own hole/caliber.
What could I do?
I suppose I should repair/replace the bush between the stearing arm pin and the caliber/ or I need a pair of new needle bearing acording to the photo?
Thanks, Benedek J
   / JD 1020 power steering #165
Whether your 1020 will need bushings or needle brgs on bellcrank shaft will be determined by tractor serial #. Bushings up to SN _-062660 & needle brgs SN 062661-
Thanks.. On my tractor I cant see the serial number plate.. But its made in 1972, theoratically the serial number sholud be starting from the number 134700.... Am I right_?!
According to your advice I need to buy the needle bearing?
   / JD 1020 power steering #167
How did you determine your 1020 was built in 1972 without having access to tractor serial #? Did you look on RH side of trans case for serial # tag? I agree 1020's built after mid-1968 should have needle brgs in this application.
I have the original tractors papers from Germany (register, stud book).
   / JD 1020 power steering #169
So registry book doesn't contain tractor serial #? I'll guess your tractors serial# is not legible or missing!
My German heritage didn't allow me to know tractors built in Germany had a book of origin. My grand parents immigrated from Germany to USA & spoke very fluent German.
You have right... I will check it... I live in Romania, but I am hungarian... I understand Englush but I cant speak... Here also lived germans.. . Transylvania, Siebenbürger... My grandgrandfather worked in USA, between 1909 and 1928, in Detroit, but he returned. We have relatíve in USA
2016 JOHN DEERE 624K WHEEL LOADER (A51246)
2016 JOHN DEERE...
INSPECTION (A51572)
INSPECTION (A51572)
Polaris Sportsman 335 4x4 ATV (A51573)
Polaris Sportsman...
NEW Wolverine Skid Steer Bucket Root Rake Attachment 31'' (A53002)
NEW Wolverine Skid...
2002 International 4300 Truck, VIN # 1HTMMAAN92H547720 (A51572)
2002 International...
