JD 1020 Hydraulic filter problem
/ JD 1020 Hydraulic filter problem #1
Figato
Well, I tried changing the fluid and filter this week.
Fluid went okay - filter - not so much.
It is in a steel bell housing under the transmission and held in place by a bolt through the center with a gasket around the rim and the whole thing is under spring pressure.
I could not seat the housing correctly without cutting the gasket (2 tries). Leaks like a river.
What is the trick (if any) to getting this to seat correctly?
help?
/ JD 1020 Hydraulic filter problem #2
Did you put the quad ring up in the trans case(using a dab of grease to hold it in place) or rest it on the filter cover and try to install quad ring and filter cover at the same time??????????
The latter.
Er... I guess that's the trick. Thanks.
