Irrigation wiring question
   / Irrigation wiring question #11
Willl said:
Can't do one without the other.
Uh.. sure you can... Each controller may have? 4 circuits. All 4 of those circuits can have a common neutral... and then discrete 'hot' leads. Move on to the next controller.. same deal.. and again.. and again. I said to not connect each controllers neutral to the next controller ( bus ).. IE.. let each controller have it's own neutral system.
It's VERY easy to have one and not the other... key here is when I said 'each controller'
soundguy
   / Irrigation wiring question #12
The bigger 'key here' is if my reply was towards you, to which is was not. :cool:
   / Irrigation wiring question #13
Then you might utilize some of the reply features availble here on this forum.. like a 'QUOTE'.. since your message appeared right under mine.. with no quotes in it.. how was anyone suposed to determine who you were replying to.. other than the person/post directly above yours... I doubt any of us are psychic here...
soundguy
   / Irrigation wiring question #14
Soundguy said:
like a 'QUOTE'.
Oops, my bad. Sorry, won't happen again.
jeffinsgf dude, sorry if I confused you too, I was replying to the OP.
Thanks for all the input. I think I am getting the picture that the power transformer "common" and the solenoid commons are all one and the same. I was treating them as separate and different in my mind. Some sketches helped. To keep things simple consider I have two 3 station controllers and four valves at two different locations. So although I wanted to do this...(pdf is a better looking copy of the same sketch)
A-Want.jpg View attachment A-Want.pdf
(because I have the four transformers that were supplied with the controllers) you seem to be suggesting I do this...
B_Need.jpg View attachment B_Need.pdf
because a ground fault/problem of one of the individual transformers could "infect" the others (or the system).
What I don't want is this...
C_Don't Want.jpg View attachment C_Don't Want.pdf
because then I could not run two valves from one location from two different controllers and some controller spaces would go to waste. IE: If I had two more valves from yet another station, this wiring would have me running it to a separate controller and Y3 and Z3 would be lost.
Here are some photos of the actual equipment. I only got two stations on line Sunday. The next three from two locations will also be connected this same controller. Then I have three at another box to connect and that's where the cross pollination would begin. To utilize the remaining 6th location on the first controller I want to join all the commons at the garage central control board.
Now the multiple questions:
So in your opinion is drawing 2 "Need This??" acceptable?
Would I use a 26VAC/3000mA transformer to power up all four controllers? Or, if I am careful to not program two controllers to operate at the same time, do I power them all from one of the 26vac/750mA transformers I have?
If the former above,running higher amps to each transformer has me concerned with overload protection. Should each transformer be then individually fused?
Is 3000mA the same as 3Amp?
Grainger has trans formers rated a V/A. What would be the V/A rating I would need to power the four controllers from a single transformer?
Thanks again for your help. A lifetime in and around construction has given me a decent education in most trades and I've become adept at many. Electrical is still my weak point. I still think it is magic!
PS. When I posted I found my jpg's converted from pdf's fell apart so I added the pdf's if you need a better look at the sketches.
   / Irrigation wiring question #16
   / Irrigation wiring question #17
I came in to this late; you already bought stuff...
I would recommend a different controller. I use the Hunter Pro-C models. I have at home, and have installed for customers, a 32 station capability. One controller. One thing to program. Multiple programs, so yo can have daily watering on one schedule, weekly on another etc.
The Hunter Pro series is the easiest to use, easiest to program unit that I have found. I found other models, and manufacturers hard enough for me to figure out, much less the customer.
   / Irrigation wiring question #18
RedDirt,
I think someone has convinced you to make this much harder than it is. The common going to the solenoids has nothing to do with the power supply from the transformer. SoundGuy had a reasonable reservation re: tracing faults, but it would be fairly easy to disconnect the various controllers if you had a fault in one. You were on the right track when you started --- stay there.
jeffinsgf said:
RedDirt,
jeffinsgf,
You keep giving me the answer I want to hear.:) At first I didn't think the power transformer and solenoid commons were directly related but replies got me thinking they must be. The valve solenoid needs its power from somewhere and the where seemed to be the hot and neutral of the incoming transformer wires.
So I'm good to go with the "A-Want" schematic in above post?
RobertN,
The four 6 station controllers were a "purchase of opportunity" at $10 -$15 (4+/- yrs ago) each and I knew a 24 valve controller would cost hundreds. I looked at the Hunter Pro-C on the web but can't find out everything that's required because of its modular design so I haven't a clue how to price check. I found other 24-36 station controllers in the $1200 $1800 range...way too expensive for my wallet.
Could you tell us a ball park cost of the 32 station model you mention? It looks ideal for my needs but hard to believe it would be within my budget. I could upgrade to a unit costing a few hundred but above that I'll have to make do even if end result wiring demands that I limit the capability/capacity of the system
   / Irrigation wiring question #20
We used the Hunter ICC. It is just like the Pro-C, except a bigger box. It is hard wired; the transformer is built in.
Looking on the web, the one I have is $175 with an 8 station module installed. It is expandable to 32 stations, using 4-station or 8-station modules; the 8 station modules appear to run $60.
Hunter ICC-800-PL - ICC Series 8 Station Controller, Plastic Cabinet (outdoor) for sprinklers and irrigation systems.
We got ours a couple years ago. Installed another one shortly after for a customer. They were less then. And, we got installer pricing. FWIW, we get all of our stuff at John Deere(used to be Green-Mark) locally.
We're running 18 stations, with room for expansion. We have the ICC-800-PL, with two additional ICM-800 modules(total 24 possible stations). We have one empty slot.
We originally had a a couple controllers. It was a pain to get them synced up. Our well supply is limited, so we have to do some creative watering(mostly drip). We had to make sure two controllers did not turn on at the same time. With multiple stations, multiple programs, it was challenging.
I have installed a bunch of the Hunter Pro-C and SRC units. Very reliable, and very very easy to set up, program etc.
RedDirt said:
RobertN,
2018 Ariens Ikon 52in Zero-Turn Commercial Mower (A56857)
2018 Ariens Ikon...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A55315)
UNVERFERTH 330 8...
2022 Brush Wolf ALPHA-XP Skid Loader Brush Cutter (A56435)
2022 Brush Wolf...
2002 Bobcat 763 Compact Skid Steer (A56435)
2002 Bobcat 763...
Deere 331G (A53317)
Deere 331G (A53317)
