Installing a window on corrugated tin
   / Installing a window on corrugated tin #1
kcflhrc
Kansas
2013 John Deere 3032E
So we are converting an old lean too building on our property to a chicken coop. It has corrugated tin siding and roofing. I need to install 2 windows on this tin siding. Any recommendations on doing this? I thought I would just frame it on the inside and outside then caulk around it. I really don't see another way to do it.
Thanks
   / Installing a window on corrugated tin #2
just a suggestion...
They make wooden slats for corrugated metal that allow the corrugations to seat flat...you could possible use it (along with some 1x) to make a better seal for the outside trim around the window...(top and bottom anyway)
   / Installing a window on corrugated tin #3
Google "windows for corrugated metal". You'll find a lot of ways to do this.
Good luck.
   / Installing a window on corrugated tin #4
The way I would do it is to run a couple of 2x4's from the ground up on the inside to make the sides of the frame for the window. If you have a dirt floor, be sure to put something under the 2x4's at the bottom.
   / Installing a window on corrugated tin #6
What type of backing do you have behind the metal? If you have (or construct) a full frame around the window you can use standard metal siding J strips. After you build the framing the correct size for the window, cut out the siding to the frame size, then cut the J strips to size and insert them over the cut edges of metal siding. Next mount the window and pull the J strips hard against the window frame. Put siding screws through the siding and back flat of the J strip and into the window opening frame. Then, if you want it fully weatherproofed, you can caulk between the J Strips and the window.
I know this may sound complex, but it's a very easy installation and will look quite finished.
   / Installing a window on corrugated tin #7
One other thought. On my window installs in the pole barn, I used a trim piece meant to go over windows and doors (has a drip edge) on the top and the J strips on the sides and bottom.
   / Installing a window on corrugated tin #8
OK, I found a picture. Not a great one but you can see the top drip edge and J-strips. This is before the siding is installed, but you cut the hole and install the trim, then insert the window without removing the siding.
The windows I bought have a nailing flange already. Not sure how the J strips will work on the corrugated material.
Kubota SVL97-2 High Flow Skid Steer  Cab A/C, Rear Camera, Quick Attach! (A50397)
Kubota SVL97-2...
2018 Dodge Ram 4500 4x4 Enclosed Service Truck (A48081)
2018 Dodge Ram...
UNUSED LANDHONOR 3PT SEED PLANTER (A50460)
UNUSED LANDHONOR...
2022 Club Car Tempo Golf Cart (A48082)
2022 Club Car...
Adams FL24 Fertilizer Conveyor - 24IN Belt, Predator Engine, 2IN Hitch, Refurbished by Manufacturer (A50397)
Adams FL24...
New/Unused 2025 CFG MX50R Mini Excavator (A48837)
New/Unused 2025...
