in floor heating
/ in floor heating #1
woodsleeboy
ontario, canada
I'm thinking about installing in floor heating in my pole barn. My building is 28x40x12. Does anyone have any info on how to do it (without spending a fortune on a commercial system?) Can I use a domestic hot water tank?
/ in floor heating #2
Do a google search on "radiant floor heat" and "hydronic floor heat" and you will get a lot of good hits.
also try the radiant panel association at:
radiant panel
Water heater use as a source depends on your local code. In WI you cannot use a water heater unless the mfr has listed radiant heat as an approved usage.
/ in floor heating #3
I'm planning on doing the same thing this year in my 30X75 building. PM me and I will send you my favorites listing for my radiant floor project. I think I have about 30 listings.
/ in floor heating #4
Assuming that you intend on installing a concrete floor, not too long ago I saw a class action suit against the manufacturer of the tubing as it had a tendency to rupture after some period of time. Just something to think about.
Overall, I hear that the heating is even and comfortable, yet slow to respond to heating demands.
/ in floor heating #5
While it is possible for a remote leak on the non metallic tube like Wirsbo, in all the years I was in the HVAC industry I saw but one leak under a concrete floor and it was plumbed with copper.
/ in floor heating #6
This is how I did it. F/BB/WP reflective insulation underneath, wire to tie the tubing to and 600' of PEX tubing for a 24' by 24' area. I will be heating it with an outside wood boiler.
New/Unused Wolverine 72in Quick Attach Brush Cutter (A65583)
New/Unused...
2006 Mack CV713 Granite Truck, VIN # 1M2AG11C06M033754 (A65563)
2006 Mack CV713...
2005 Chevrolet Express Van, VIN # 1GCFG15X351255714 (A65563)
2005 Chevrolet...
KBH Tender (A63689)
KBH Tender (A63689)
2001 Nissan Frontier Pickup Truck (A62613)
2001 Nissan...
2005 Mack Vision CNX613 (refurbished and retrofitted as novelty pick-up)  (A62613)
2005 Mack Vision...
