Importing and modifying a new mini excavator from China
   / Importing and modifying a new mini excavator from China #311
Insane! $2000 more after paying CIF AND state tax to import this machine. Still cheaper than buying a used brand name machine, but I don't think now is the time for me. They certainly seem worth the money but the duty of 25% just ruins it for me.
   / Importing and modifying a new mini excavator from China #312
I received mine this week. Minus the frustrations dealing with Vanguard Logistics (CFS), it was pretty painless process. Everyone always suggests buying as many attachments as you can, but I figured I didn't "need" some of the other things like a wider bucket or a tilt bucket and now i've already got things i wish I would have bought those for.
   / Importing and modifying a new mini excavator from China #313
Nice! Keep us posted how you like it I’m curious to see how these little China diggers hold up overtime.
Congrats. Did your Hightop come with hyd oil cooling and return filtration?
Protect your boom cylinder hoses by flipping the cyl around. Newer units have 30mm boom cylinder pins. Mine are only 25mm.
   / Importing and modifying a new mini excavator from China #315
Yes, it has the cooling and filtration on it. Feel like i need to add another fan in there to "try" and keep the engine from heating that whole compartment under the seat so much.
Yes, an electric fan helps a lot. Also, most of the gasoline conversions do not duct the flywheel fan to get outside air, as they do with the diesel. The B&S 2100 engine should have plenty of output to run a fan without discharging the battery. My own Duromax 420 has only one charge coil, so not as good.
Oh, and routing the muffler outside of the house is important, too. It gets hot inside there!
   / Importing and modifying a new mini excavator from China #317
Twenty-nine of these just sold at Richie Brothers in Dunnigan CA. Around 5000 + tax and fees. I registered for the auction but missed it somehow. Probably best to miss as I do not need one anymore.
Andy
Link to Auction
   / Importing and modifying a new mini excavator from China #318
A question for owners: do you happen to tow anything with your mini excavator? What could be the towing capacity of these small machines?
My machine has the 2-cylinder diesel EV80 engine, weights around 1.1 metric ton, and thinking about to attach a small trailer behind it, and try to carry some gravel on it. I live on a hillside, so it has some incline too.
Tried find some info on this topic, without luck. Thank you in advance.
   / Importing and modifying a new mini excavator from China #319
I tow my trailers with my KX-040. I think you could tow a trailer equal to it’s own weight on fairly flat ground. The biggest problem is excavators have weak final drives. They aren’t like other equipment that can put good power to the ground. They barely move themselves.
   / Importing and modifying a new mini excavator from China #320
Thank you for your response. The Kx-040 is a monster compared to my little machine. As I read here, these chinese machines could have problems with descending on a slope without any extra load, since the motors drive the tracks directly.
SD Launch SDLB25 (A53317)
SD Launch SDLB25...
2006 TerraGator 8104 (A56438)
2006 TerraGator...
iDrive TDS-2010H...
22FT Roadway Dry Van Pup Trailer (A56438)
22FT Roadway Dry...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
