Implements operate jerky
/ Implements operate jerky #1
Wood Hound
Houston, TX
Mahindra 3016
The rear implements on my rear top-n-tilt operate very jerky when changing position when moving in down direction. My restriction orifice doesn't seem to help. How does the orifice work and on which hydraulic line. Are there any other recommendations to smooth out the operation?
/ Implements operate jerky #2
Restriction orifice needs to be in the line that control flow out of cylinder when lowering or moving via gravity especially if you have PO check in the circuit.
/ Implements operate jerky #3
A couple of things. You will find that the whole system works better to have a flow restrictor at each port.
So you should have 4x .030 restrictors for your top & tilt set.
Second thing, try feathering the controls.
2023 CATERPILLAR 259D3 SKID STEER (A65053)
2023 CATERPILLAR...
2019 Ford F-150 4x4 Pickup Truck (A64556)
2019 Ford F-150...
Landhero LDH-TWP80, Gasoline Water Pump (A62679)
Landhero...
2022 EZ-GO ELITE...
1999 GROVE MZ66DXT TELESCOPIC BOOM LIFT (A65053)
1999 GROVE MZ66DXT...
DRILL CABINET SKID (A60736)
DRILL CABINET SKID...
