IH 706
/ IH 706 #1
jsberhow
Looking at using a IH706 to pull a 13' John Deer 110 Disk. Any thoughts on this? I think that this may be pushing the limits.
/ IH 706 #2
I pulled a John Deere 12 ft. AW disc for years with a 3020 JD (65 hp) with no problem at all. Ken Sweet
/ IH 706 #3
We used to pull a 10' with an old 60 JD and a 706 is way more tractor than that. It should pull that no problem.
Kim
/ IH 706 #4
I think the 706 is 70 hp at the drawbar ... depending on soil you should be good. You can always lift it out of the ground a little with the Hyd's if need be.
I pull 10' with 55 hp ... sometimes in light ground when the disc is going in past the center of the blades I have to bring it up some.
/ IH 706 #5
My gasser 706 has 65 engine HP. I believe the diesel has a couple more ponies. With the TA for the tough pulling spots you should be fine.
/ IH 706 #6
I use to pull a 12' international disc with my Ford 7710-II which is 86hp from the factory. It was actually turned up and was putting out 120hp. I farm heavier ground then most so it pulls harder then it should depending on ground conditions. If the ground was too wet you will struggle but if its not a power issue, its a traction issue. When the ground conditions are perfect I can pull that disc with my TN65. A 706 should have no trouble.
/ IH 706 #7
the JD 110 is a lighter disc and the 706 should be able to pull it!
2001 FREIGHTLINER FL80 6X4 T/A VACUUM TRUCK (A67148)
2001 FREIGHTLINER...
Loudo Trailers 20ft. T/A Utility Trailer (A64557)
Loudo Trailers...
17in. Bucket w/ Teeth Excavator Attachment (A64194)
17in. Bucket w/...
(2) CHROME STEP BARS (A64276)
(2) CHROME STEP...
2022 EZ-GO ELITE...
JOHN DEERE 1705 - 6R36" VACUUM PLANTER (A64278)
JOHN DEERE 1705 -...
