IH 706
/ IH 706 #1
jsberhow
Looking at using a IH706 to pull a 13' John Deer 110 Disk. Any thoughts on this? I think that this may be pushing the limits.
/ IH 706 #2
I pulled a John Deere 12 ft. AW disc for years with a 3020 JD (65 hp) with no problem at all. Ken Sweet
/ IH 706 #3
We used to pull a 10' with an old 60 JD and a 706 is way more tractor than that. It should pull that no problem.
Kim
/ IH 706 #4
I think the 706 is 70 hp at the drawbar ... depending on soil you should be good. You can always lift it out of the ground a little with the Hyd's if need be.
I pull 10' with 55 hp ... sometimes in light ground when the disc is going in past the center of the blades I have to bring it up some.
/ IH 706 #5
My gasser 706 has 65 engine HP. I believe the diesel has a couple more ponies. With the TA for the tough pulling spots you should be fine.
/ IH 706 #6
I use to pull a 12' international disc with my Ford 7710-II which is 86hp from the factory. It was actually turned up and was putting out 120hp. I farm heavier ground then most so it pulls harder then it should depending on ground conditions. If the ground was too wet you will struggle but if its not a power issue, its a traction issue. When the ground conditions are perfect I can pull that disc with my TN65. A 706 should have no trouble.
/ IH 706 #7
the JD 110 is a lighter disc and the 706 should be able to pull it!
CASE INTERNATIONAL 893 - 6R36" CORN HEAD (A63291)
CASE INTERNATIONAL...
2017 Ford F-250 Ext Cab Pickup Truck (A61573)
2017 Ford F-250...
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
207282 (A52708)
207282 (A52708)
1999 CATERPILLAR 312B EXCAVATOR (A52709)
1999 CATERPILLAR...
2016 CATERPILLAR 416F2 BACKHOE (A62129)
2016 CATERPILLAR...
