IH 255 Compact tractor
/ IH 255 Compact tractor #11
I have a 1988 case IH 255 and I am in the process of purchasing a loader with 60" bucket. I do not have power steering and it is 4WD. I discovered Bush Hod can still make the loader; however, they do not have the Manifold Hydraulic Valve needed to attache the hydraulic lines. The said it is no longer made. The part# per CNH Parts and Service Catalog is 1960659C1. Do you have any idea where I may acquire this part, new or used. I would also be interested in purchasing a good used loader attachment, if I could find one. The loader attachment I am currently thinking of purchasing is an 1847QT, with everything supplied but the Manifold Hydraulic valve. I would appreciate any help that could be given.
/ IH 255 Compact tractor #12
Messicks has it listed for $147.35 Part Search
I assume this is the block that bolts to the side of the trans case and supplies hydraulic pressure and return? If this part is not available, it is very easy to splice the hard line coming from the pump and plumbing a return to tank line. I have done this on a similar model. Not as clean but just as effective.
2016 FORD TRANSIT T250 CARGO VAN (A59575)
2016 FORD TRANSIT...
2021 SANY SY365C9C5K (A58214)
2021 SANY...
2014 FORD F-450 XL SUPER DUTY SERVICE TRUCK (A59823)
2014 FORD F-450 XL...
2020 PETERBILT PB337 SERVICE TRUCK (A59823)
2020 PETERBILT...
KJ K0720 7'x20' Metal Gate (Deep) (A60463)
KJ K0720 7'x20'...
Mini Ex Rake Attachment (A60463)
Mini Ex Rake...
