First tractor
/ First tractor
I can't believe it, I got the owner's manual, and feel it is about 95+% correct for my tractor. The part that doesn't fit my tractor is the trans/hydraulic oil fill port. The manual shows a dipstick on top of the trans cover between my feet as I sit in the seat, mine does not have that, it has the sight window on the rear next to the PTO shaft. It also shows the fill port somewhere on the rear of the trans.......................I can't find ANYTHING in that area that would be the port.
It is painfully obvious that this manual was not written by English fluent writers(I know this has nothing to do with finding my oil inlet port, but it does make it more difficult to stay on a train of thought)!
I have already learned alot of good info, seeing as how this is my first tractor, so this manual is not a total loss.
On with my quest to put hydraulic oil in my tractor...............the way is bound to show itself eventually.
thanks again and any info will still be appreciated
Redraider
/ First tractor #34
Just an idea.
I think from reading through the posts, the loader was added later on.
There could be a chance, that whoever installed the loader, used the fill port as return for the loader valve.
Track the hoses from the loader valve to the back of the tractor. You might find something.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
2008 MACK CHU613 DAYCAB (INOPERABLE) (A58214)
2008 MACK CHU613...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
CAT CB34 (A60462)
CAT CB34 (A60462)
TraxMax Stand-On Tracked Sod Installer (A59228)
TraxMax Stand-On...
