Ignition switch
/ Ignition switch #1
Moak
Greenfield Center
Massey Ferguson 3165 Bronson 2610H
I washed my 2610H today but doing this is nothing new for me but I did leave the key in it instead of pulling the key and putting the cap on. Now I don't know if this issue is because I did this or not. But now when I go to start the tractor as soon as I put the key into the position where the glow plug light comes on the tractor starts and it sounds like the start is still spinning until I turn the key off. I did notice when I pull the key it's wet. Has anybody else had or heard of something like this happening?
/ Ignition switch #2
While it doesn't happen with the ignition switch, the clutch safety switch on mine will act up occasionally if I wash the tractor or if it happens to take a rain shower.
I do put the cap over the ignition switch when washing the tractor to prevent exactly what happened to you.
You probably need to take the ignition switch out and try to shake it so it pulls as much water out as possible, then soak it with WD 40, since it's a water displacement.
/ Ignition switch
I went back out with my heat shrink gun and let it blow into the ignition switch for a bit and once the ignition switch felt warm I turned it off and let sit a minute and it worked perfectly. Everything seems to be good I will never wash it again with the key in the ignition cylinder or without the cap on.
2015 JOHN DEERE 644KH HYBRID LOADER (A66091)
2015 JOHN DEERE...
2018 GENERAC MOBILE PRODUCTS MLT6S (A68842)
2018 GENERAC...
2017 GMC Sierra 2500 HD 4x4 Crew Cab SpaceKap Service Truck (A66736)
2017 GMC Sierra...
2017 Chevrolet Equinox SUV (A66738)
2017 Chevrolet...
2021 CATERPILLAR 420XE HRC BACKHOE (A65053)
2021 CATERPILLAR...
24Wx25Lx12H Two Car Metal Garage | Durable Metal Garage
24Wx25Lx12H Two...
