All In A Days Work
- Joined
- Dec 13, 2014
- Messages
- 185
- Location
- Chelan, WA.
- Tractor
- Kubota L4701, Land Pride RB3784 Rear Blade, Bearcat SC5540 Chipper Shredder
I had not checked the tire pressure in my tires for couple years, it's not used all that much. I noticed they were bulging some the other day and decided to check the pressure, neither rear tire would indicate air pressure. I checked the gauge on front tire it works. I started airing up the tires, I could hear that the valve stem was below the fluid level. I checked 5 lbs. ok good, here is where things went bad. I just wasn't thinking clearly, the next thing I know I had 35 psi in one of the tires. I tried to let some out but after I lost some Rim Guard, I decided I needed to come up with another plan. The tires are the 17.5 x 24" Ag tires, the manual states that they would have about 600 lbs. of Rim Guard in each tire.
The dealer told me it would be best to lay the tire down to adjust the air. So here is the plan, in my pole barn there is a center beam that I thought I would hang a pulley from and then with my portable winch I could hold the tire while unbolting and then lay it down to let some air out.
How does that sound?
