Smokeydog
Elite Member
Bought new HD 12 ply, extra deep thread skid steer tires to replace the worn and one slow leaking OEM tires on the Kubota front M59 a few years ago. Great improvement in traction especially loader work. Also pumped in about a half gallon of Gempler’s bulletproof tire sealant in each tire for extra protection. I only check air pressure once a year unless I see a problem. These tires don’t squat at low pressure like the OEM tires. Noticed pressure in a year would drop from 45 to 10-15psi. Don’t know if pressure loss is from leak or reaction to sealant??? Max pressure in these tires are 80psi.
Not checking pressure more regularly caught up with me yesterday. While grubbing up brush and small trees rolled a front tire off the rim on one side.
Had to wipe off a lot of mud and sealant. Took the tire to a Bobcat dealer. Service said $150 and next day to fix because of their high hourly rate. Took it to a tractor tire shop, $5 repair plus $10 tip for fixing while I waited. Takes 6’ tire irons with lots of tire grease to mount and seat seat high ply, rim guard tires.
I’ll be checking pressures more often.
