I need help finding a side link pin
/ I need help finding a side link pin #1
davrow
Riverside, CA
Kioti CK27HST
This for the 3 pt on a Kioti. The pin is 5/8" x 2-1/2".
This is the one that wasn't pulled out and lost mowing brush.
The biggest issue is the square head. I cannot find square head clevis pins anywhere.
I can find round head pins, anywhere from $1.34 to $17.79. I think I'll try the $1.34 one ... ;)
But does anyone know where I can find square head pins?
I do not have a local Kioti dealer. I'll try the local Kubota dealer next week.
Thanks
/ I need help finding a side link pin #2
Should be Kioti part number 34354-7158-3. Lots of dealers would be happy to mail you one or two. For that location, I would consider using cotter pins (keys)instead of the hitch pin clips. Less chance of losing them and how often do you change the pin location anyways?
/ I need help finding a side link pin #3
I wonder if it really needs to be square head??... The square head may only keep it from rotating which I don't think is a real issue except in some engineers mind.... All the head is for is a permanent stop to keep from having to use two linch/hair/cotter pins....
Simple solution would be go to local tractor supply get pin of correct diameter , and if it's to long cut it down and redrill hole for "pin" ... Probably go with suggestion to use a cotter pin to secure it.... IF it really, really needs to be square use a grinder on round head to make it fit in square hole....
Been experiment on how to keep pins in place on my GC 1715 and two JD mowers and the cotter pin seems to work best on areas where pin is not removed regularly....
Thanks, all!
/ I need help finding a side link pin #6
Instead of a cotter pin check harbor freight for a box of clips
willy
/ I need help finding a side link pin #7
I'd at the least knock that hitch pin in all the way.
1992 Fontaine Trailer 44ft (A62679)
1992 Fontaine...
2020 VOLVO EC200EL EXCAVATOR (A64279)
2020 VOLVO EC200EL...
Vermeer 605 Super F Round Baler (A65640)
Vermeer 605 Super...
(10) New CATERPILLAR Keys (A65579)
(10) New...
New/Unused Electric Winch (A65583)
New/Unused...
Wolverine Quick Attach Tiller (A66285)
Wolverine Quick...
