i know it's reality...
/ i know it's reality...
just tried it a few times and nothing. will charge again and try or leave charged before the rain comes and i sit with a low/dead battery.
last year and this year i swore i would start it before it got real cold or the stuff hits the fan but last year and worse this year it was pretty cold and storming/raining badly so to drain the battery and not be able to plug in safely to charge outside i was kind of stuck. If i were up in NY i would have a heater or hopefully a shelter and alsobe using it more at this time of the year. with mud tough to do even though there is plenty of wood and chips to move and stack/store.
i was going to say - last year when i had the issue and snow to move - 2 or 3 days later it warmed up into the 40's glow plugs 1 cycle and started right up! that may be the case this despite the diesel additive. I was generous in using it too.
/ i know it's reality... #23
Some people keep the battery in the house except when using the tractor. Warm batteries work better.
Bruce
/ i know it's reality... #24
If you have electricity at the tractor, your easiest solution is a simple electric hair dryer. Just remove the air filter cap, turn you hair dryer on hi heat and blow the hot air into the air filter while cranking over the engine. No glow plugs needed. I use to have to start my old 4220 Yanmar that way since it had not glow plugs.
Blowing that hot air directly into the engine is way better than glow plugs anyway. It doesn't do anything for the cold thick engine oil though so take it easy on the throttle till your engine warms up a bit. If you are living in a sub artic zone, a block heater is almost a must to have OR a magnetic attached oil pan heater. Either of these would help the oil circulation problems. A good synthetic 0W-30 engine oil would work also.
PS Might be best if you bought your own hair dryer rather than pinching the wife's. Less hassle in the long run. It don't need to be fancy with 6 different heat settings, just a simple $15 one should work well.
well notta. anyway - i love my machine and that is why i bought after very careful thought. 3/4 of the year - wow! the few times i need it for snow in winter it is a freakin dud!!! last yeear not knowing about gelling until my first experience - and thanks to you people here for telling me about diesel gelling.... i never owned a diesel before. so this year i was prepared and wham - BS> I am quite ticked i have neighbors with orange and green and they keep outside or unheated areas and 1 guy beats the **** out of them and they seem to have no issues. well end of my rant.... I am just ticked! otherwise i love the machine!
/ i know it's reality... #26
Don't know if anyone has suggested but have you cleaned the ground connection off the battery were it meets the frame? Just had a 3016 in that turned over fine but just smoke... it was getting enough to turn the engine but not enough connection to actuate the plugs. put 12 to the plug rail and she popped right off... cleaned up the ground and good to go.
i cleaned the terminasl a couple of months back but not to the frame? stupid question where is it located? and i take it it is the negative DUUUUHHHH!
duh was to me not you....
/ i know it's reality... #28
follow the ground from the battery to were it connects to the frame of the tractor. unbolt it and clean both the frame and ground connector really well.
/ i know it's reality... #29
wire brush and sand cloth is your friend
/ i know it's reality... #30
I had the same problem yesterday. Engine cranked but would not start. No smoke from stack. Fuel was getting to the fuel filter. Took off filter and found water frozen in the bottom of the retainer cap. I guess it was from condensation in the fuel tank. You might want to check your fuel filter.
tried - not for a couple of minutes but a while - also tried back to back too many times and nothing - gets abit warmer and starts no problem. got serious snow here yesterday and today and I have a tractor statue! will try tomorrow after topping the battery off again. sucks to be honest!
/ i know it's reality... #34
I checked my glow plug rail with a multi-meter, it's only powered up while the glow plug light is on.
I just wanted to let you know, since I was the one that suggested to turn the key on and walk away for a few minutes...
/ i know it's reality... #36
/ i know it's reality... #37
Most modern tractors have drain, at bottom of the main fuel filter. If your has a lot of moisture it is likely frozen and stopping fuel flow. Use a hair dyer or the like to warm bottom of fuel filter then open drain and turn your key to run (not start) which will operate fuel pump. Continue until you get pure fuel out then turn key off and close drain. If fuel is your issue tractor should start.
Good luck!
Sent from my iPad using TractorByNet
/ i know it's reality... #38
If I turn my ignition switch all the way back it will bring on the glow plugs for as long as it is held in that position. Probably many different setups for this but just a thought. I use a block heater and the glow plugs seldom come on if it has been plugged in.
/ i know it's reality... #39
Nothing can tick me off more than the issue you are having and its not just the color of the tractor ... My JD 5520 is the worst to start under 35 degrees ... I've just learned thats the way it is ... so I park the heifer in the shed and put the torpedo heater on it while im doing the feeding of grain ... then crank the heifer to haul hay ... Ive called her alot of names !!!
/ i know it's reality... #40
How much power is it getting?
ECONO SHELLER FOR PEA / BEAN (A63291)
ECONO SHELLER FOR...
Year: 2003 Make: International Model: 4300 Vehicle Type: Truck Mileage: 2,048 Plate: Body Type: T... (A61573)
Year: 2003 Make...
2016 Hyundia 53' Dry Van Trailer (A62613)
2016 Hyundia 53'...
2008 Ford F-250 4x4 Crew Cab Pickup Truck (A61573)
2008 Ford F-250...
2005 Manac 48' x 102" Aluminum Fixed Spread Axle Trailer (A62613)
2005 Manac 48' x...
2017 Bobcat T550 Compact Track Loader Skid Steer (A61572)
2017 Bobcat T550...
