Hyrdaulics for Dummies
   / Hyrdaulics for Dummies #21
Yes use the PB to feed the down stream valve just like the drawing shows.
You can use a Tee on the return lines, I think you know that, but thought I would just bring it up.
Sorry about short post before ,but with the drawing I thought you had it, and was just wanting to make sure.
Lee
   / Hyrdaulics for Dummies #22
So just connecting another valve in-line with my backhoe WON'T work like I was told earlier ?
The 2 valves MUST be piped like the picture I posted ?
   / Hyrdaulics for Dummies #23
Willl, sorry, I missed your question...:eek:
Since your backhoe and FEL valve does not have PB, you can series the valve as stated before. This is for your JD that has a PB loop. Other tractors that have the remote mounted FEL valve and easy access to the tank should your the PB sleeve on the FEL valve...but on the JD's it's a little different setup.
2011 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A59575)
2011 FREIGHTLINER...
2016 KOMATSU PC360LC-11 EXCAVATOR (A58214)
2016 KOMATSU...
2020 SAVANA 3500 16FT BOX TRUCK (A59575)
2020 SAVANA 3500...
2018 CATERPILLAR 242D SKID STEER (A60429)
2018 CATERPILLAR...
2015 GENIE GS-4047 ELECTRIC SCISSOR LIFT (A52706)
2015 GENIE GS-4047...
40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
40ft T/A Gooseneck...
