3rd function
/ 3rd function #11
I guess I don't understand. The subplate has 1/2 inch orb threads. Why would they make the whole in the subplate so much smaller than the whole in a 1/2 fitting?
I have no idea why,:unsure: but again, the through holes in a 1/2"- 1/2" fitting are just over 3/8".
The hole on the subplate can easily be drilled out to match those on the valve. The 4 valve ports are .300" which is too small for your tractor's implement GPM of 12 GPM.
If you don't want to be worrying about having any hydraulic issues down the road, you need a different valve and sub-plate.
Maybe they figure that the reduced length is short enough not to make a difference? If the tank volume is large enough, it will keep the fluid at a low enough temp to not make a difference.
I'm sure that a lot of people get away with what you have, but that does not make it right IMO.
Good luck with your decisions. :)
/ 3rd function #12
When ever the tractor is operating the flow is going into the P port and out the tank port of the valve so ALWAYS in the circuit.
Drill size in subplate depends on design. Most companies have a minimum wall thickness that they maintain between drill paths.
/ 3rd function #13
Third function solenoid valves are different sizes and are sold by gpm flow rating. Obviously match the right one to your tractors gpm and should be no worries. Which valve do you have?
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
2008 Freightliner Allegro Bay Class A Motorhome (A59231)
2008 Freightliner...
2014 Dodge Charger Sedan (A59231)
2014 Dodge Charger...
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58214)
1999 WEST WIND...
2007 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2007 Ford F-150...
