Hyrdaulics for Dummies
/ Hyrdaulics for Dummies #21
Yes use the PB to feed the down stream valve just like the drawing shows.
You can use a Tee on the return lines, I think you know that, but thought I would just bring it up.
Sorry about short post before ,but with the drawing I thought you had it, and was just wanting to make sure.
Lee
/ Hyrdaulics for Dummies #22
So just connecting another valve in-line with my backhoe WON'T work like I was told earlier ?
The 2 valves MUST be piped like the picture I posted ?
/ Hyrdaulics for Dummies #23
Willl, sorry, I missed your question...:eek:
Since your backhoe and FEL valve does not have PB, you can series the valve as stated before. This is for your JD that has a PB loop. Other tractors that have the remote mounted FEL valve and easy access to the tank should your the PB sleeve on the FEL valve...but on the JD's it's a little different setup.
MASSEY FERGUSON 2605 TRACTOR (A62130)
MASSEY FERGUSON...
KUBOTA KX080-4S2 EXCAVATOR (A64277)
KUBOTA KX080-4S2...
Dodge 5500 4x4 Altec Bucket Truck (A63689)
Dodge 5500 4x4...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A61307)
2014 Doyle Dry...
Landhonor Mini Excavator Ripper Tooth (A66285)
Landhonor Mini...
