Hydrostatic trans. question for 2305
/ Hydrostatic trans. question for 2305 #1
davkir
Hendricks Co., In
JD 2305 W/CC & R4
I just got an LX-4 cutter for my 2305 and used it the first time. It works great for cutting the pastures, but the ride was very rough. I ended up with 10 psi in the tires and a piece of plywood with some foam on it between the seat and the rubber cushions. That helped quite a bit.
I could mow using nearly the highest speed in the low range or at a low speed in the high range.
Which is easier on the trans? It seemed to put out a little more heat in low range, but that's just am impression.
Thanks in advance!
Thanks in advance!
/ Hydrostatic trans. question for 2305 #3
I hope that's 10 psi in the rear tires. You can easily push the front tires right off the rims at lower than about 20-22 psi in them.
Sounds like you're putting in a plug for the newer seat on the 2520 and probably the 2320.
Ralph
/ Hydrostatic trans. question for 2305 #4
Ralph
/ Hydrostatic trans. question for 2305 #5
Careful with that poor radiator mount. You can damage the radiator on rough ground.
/ Hydrostatic trans. question for 2305 #6
Tube Line Manure Spreader Nitro 750 (A63688)
Tube Line Manure...
TerraGator L3020G4 (A64119)
TerraGator L3020G4...
2011 KUBOTA KX91-3 SERIES 2 EXCAVATOR (A64279)
2011 KUBOTA KX91-3...
PALLET FORK ATTACHMENT FOR MINI SKID STEER (A61572)
PALLET FORK...
2023 Cat 259D3 Skid Steer (A64194)
2023 Cat 259D3...
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
