Hydrostatic trans. question for 2305
/ Hydrostatic trans. question for 2305 #1
davkir
Hendricks Co., In
JD 2305 W/CC & R4
I just got an LX-4 cutter for my 2305 and used it the first time. It works great for cutting the pastures, but the ride was very rough. I ended up with 10 psi in the tires and a piece of plywood with some foam on it between the seat and the rubber cushions. That helped quite a bit.
I could mow using nearly the highest speed in the low range or at a low speed in the high range.
Which is easier on the trans? It seemed to put out a little more heat in low range, but that's just am impression.
Thanks in advance!
Thanks in advance!
/ Hydrostatic trans. question for 2305 #3
I hope that's 10 psi in the rear tires. You can easily push the front tires right off the rims at lower than about 20-22 psi in them.
Sounds like you're putting in a plug for the newer seat on the 2520 and probably the 2320.
Ralph
/ Hydrostatic trans. question for 2305 #4
Ralph
/ Hydrostatic trans. question for 2305 #5
Careful with that poor radiator mount. You can damage the radiator on rough ground.
/ Hydrostatic trans. question for 2305 #6
2021 HYUNDAI HX220L EXCAVATOR (A60429)
2021 HYUNDAI...
2019 Caterpillar 239D3 Compact Track Loader Skid Steer (A61572)
2019 Caterpillar...
2016 DODGE RAM 1500 4x4 CREW CAB PICKUP TRUCK (A59912)
2016 DODGE RAM...
Takeuchi TL10V2 High Flow Compact Track Loader Skid Steer (A61572)
Takeuchi TL10V2...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A63291)
KNOW BEFORE YOU...
2012 GMC Sierra SLE 4x4 Crew Cab Pickup Truck (A61573)
2012 GMC Sierra...
