Hydrostatic trans. question for 2305
/ Hydrostatic trans. question for 2305 #1
davkir
Hendricks Co., In
JD 2305 W/CC & R4
I just got an LX-4 cutter for my 2305 and used it the first time. It works great for cutting the pastures, but the ride was very rough. I ended up with 10 psi in the tires and a piece of plywood with some foam on it between the seat and the rubber cushions. That helped quite a bit.
I could mow using nearly the highest speed in the low range or at a low speed in the high range.
Which is easier on the trans? It seemed to put out a little more heat in low range, but that's just am impression.
Thanks in advance!
Thanks in advance!
/ Hydrostatic trans. question for 2305 #3
I hope that's 10 psi in the rear tires. You can easily push the front tires right off the rims at lower than about 20-22 psi in them.
Sounds like you're putting in a plug for the newer seat on the 2520 and probably the 2320.
Ralph
/ Hydrostatic trans. question for 2305 #4
Ralph
/ Hydrostatic trans. question for 2305 #5
Careful with that poor radiator mount. You can damage the radiator on rough ground.
/ Hydrostatic trans. question for 2305 #6
2020 McCloskey R155 Trommel Screener (A61572)
2020 McCloskey...
2021 SANY SY265C LC LONG REACH EXCAVATOR (A63276)
2021 SANY SY265C...
2019 John Deere 1775NT Planter (A63111)
2019 John Deere...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
2023 John Deere 6R 175 Tractor (A63111)
2023 John Deere 6R...
2007 Montone AD24465448 30ft. Tri-Axle End Dump Trailer (A61573)
2007 Montone...
