Toplink hydraulic top link
   / hydraulic top link
well thanks for the help everybody ,I will have to make some calls and find out who makes cat 2 hydraulic top links with check valves. called ccm only sells cat 1 , it is hard to go up from cat 1 to cat 2 , ( like from top link to implement)but I could cut off end of top link and weld on new cat 2 fitting
   / hydraulic top link #12
</font><font color="blue" class="small">( but I could cut off end of top link and weld on new cat 2 fitting)</font>
That will be your only option as no one else sells top links with double pilot operated check valves.
   / hydraulic top link #13
<font color="blue">That will be your only option as no one else sells top links with double pilot operated check valves.
</font>
Actually, there is another option if one needs to buy both the control valve AND the cylinders.
I bought Prince valve sections which have pilot operated check valves built in. They lock the cylinders in place when the control handle is centered.
One shortcoming might be that if a hose should break/leak, the cylinder will not stay locked in position as it would when the PO check valves is piped directly to the cylinder ports at the cylinder. This is not an issue for my use on the 3PH.
I am satisfied with doing it this way...one positive is that since the PO check valves are in the control valve, any cylinder can be used.
   / hydraulic top link #14
</font><font color="blue" class="small">( That will be your only option as no one else sells top links with double pilot operated check valves. )</font>
Not true. Check Integration Engineering. Good luck though, in getting them to answer email. I'm still trying to find out if they make a Cat 2 cylinder myself.
//greg//
   / hydraulic top link #15
Integration Engineering is no more. Their entire inventory has been consigned to CCM for sale. Check with Mark Carter (CCI) to see what ends he has left. He is only advertising Cat 1 at this time.
   / hydraulic top link #16
</font><font color="blue" class="small">( Integration Engineering is no more. )</font>
Good grief, no wonder they're incommunicado.
You think a firm in that position would have the consideration shut down their website .... or at least put up an "out of business" autoresponder on the email server........
//greg//
   / hydraulic top link #17
<font color="blue"> Integration Engineering is no more</font>
Doesn't surprise me, I purchased my top & tilt from IE and things were a bit shaky even back then. The product however was first rate.
Kinda wondered what ever happened as the name seemed to drop off the face of the earth.
   / hydraulic top link #18
Our First Choice catagory 2 runs 22 1/4 inches (center to center) closed length--Ken Sweet
   / hydraulic top link #19
</font><font color="blue" class="small">( Our First Choice catagory 2 runs 22 1/4 inches (center to center) closed length--Ken Sweet )</font>
With double pilot operated check valves?
they are still around I just spoke to jim on the phone sent him a email day before and was answered the next day with cell # so as to make it easy to call him .he does not have cat 2 top links for those who are looking for one .but his cat 1 is a 2.5 cylinder and rod dia. is 1.25 thick with p/o check valves .gearmore uses cat 2 with 3 in cylinder 1 1/8 in rod and pressure reduce valves for slower motion and no p/o check valves . ccm uses 2in cylinder and 1 1/8 rod and p/o check valves . price on the intergration was 265, gearmore was 300, ccm was 170, ccm has much better price but intergration has bigger cylinder and larger rod dia.hope this helps those who might be looking
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2012 International Prostar (A56438)
2012 International...
TOPCAT HCRC 72" HYD BRUSH CUTTER (A52706)
TOPCAT HCRC 72"...
Case-IH 160 Puma (A57148)
Case-IH 160 Puma...
Toro Three wheeler sand pro (A56859)
Toro Three wheeler...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
