Hydraulic problems
/ Hydraulic problems #1
jwmoore
United States
Yanmar 2220D
I have a Yanmar 2220D with a Koyker 155 fel. The bucket takes forever to tilt back. It tilts forward and goes up and down like it is suppose to. I have replaced the control valve and changed the hydraulic oil and cleaned the strainer. Any suggestions?
/ Hydraulic problems #2
Are the loader hydraulics attached by quick connects?
/ Hydraulic problems #3
Sounds like one or both piston seals may have failed. Does it improve with higher engine speed? Is it worse with a load in the bkt? If one or both seals are bypassing, you may be able to hear it if you stand close, or feel the flow with your hand.
/ Hydraulic problems #4
If you can check the temp on each cyl above and below the piston. Should tell you real quick after it has ran long enough to get good and warm.
/ Hydraulic problems #6
Actually the most temperature rise will be right at the piston. This is a great mess free troubleshooting method. As little as 5 degrees of temp rise as compared to the rest of the barrel has been 100% successful for me over many years.
CATERPILLAR PC306 PLANER (A65053)
CATERPILLAR PC306...
2018 FREIGHTLINER M2 FORESTRY UTILITY BUCKET TRUCK (A63276)
2018 FREIGHTLINER...
2021 Peterbilt 389 Sleeper Truck (A62613)
2021 Peterbilt 389...
2021 CATERPILLAR 730 OFF ROAD DUMP TRUCK (A62129)
2021 CATERPILLAR...
2020 FREIGHTLINER 114 SD CEMENTECH VOLUMETRIC MIXER (A65643)
2020 FREIGHTLINER...
6' 3Pt Disk (A66285)
