Hydraulic problems
/ Hydraulic problems #1
jwmoore
United States
Yanmar 2220D
I have a Yanmar 2220D with a Koyker 155 fel. The bucket takes forever to tilt back. It tilts forward and goes up and down like it is suppose to. I have replaced the control valve and changed the hydraulic oil and cleaned the strainer. Any suggestions?
/ Hydraulic problems #2
Are the loader hydraulics attached by quick connects?
/ Hydraulic problems #3
Sounds like one or both piston seals may have failed. Does it improve with higher engine speed? Is it worse with a load in the bkt? If one or both seals are bypassing, you may be able to hear it if you stand close, or feel the flow with your hand.
/ Hydraulic problems #4
If you can check the temp on each cyl above and below the piston. Should tell you real quick after it has ran long enough to get good and warm.
/ Hydraulic problems #6
Actually the most temperature rise will be right at the piston. This is a great mess free troubleshooting method. As little as 5 degrees of temp rise as compared to the rest of the barrel has been 100% successful for me over many years.
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58216)
2011 MAGNUM...
UNUSED WOLVERINE RPR-12-72W 72" RIPPER (A62131)
UNUSED WOLVERINE...
2013 GREAT DANE  TANDEM AXLE 48FT DRY VAN TRAILER W/CRANE (A59909)
2013 GREAT DANE...
Kubota SVL97-2 Skid Steer (A61166)
Kubota SVL97-2...
2014 Bobcat T650 (A60462)
2014 Bobcat T650...
6053 (A61165)
6053 (A61165)
