Hydraulic problems
/ Hydraulic problems #1
jwmoore
United States
Yanmar 2220D
I have a Yanmar 2220D with a Koyker 155 fel. The bucket takes forever to tilt back. It tilts forward and goes up and down like it is suppose to. I have replaced the control valve and changed the hydraulic oil and cleaned the strainer. Any suggestions?
/ Hydraulic problems #2
Are the loader hydraulics attached by quick connects?
/ Hydraulic problems #3
Sounds like one or both piston seals may have failed. Does it improve with higher engine speed? Is it worse with a load in the bkt? If one or both seals are bypassing, you may be able to hear it if you stand close, or feel the flow with your hand.
/ Hydraulic problems #4
If you can check the temp on each cyl above and below the piston. Should tell you real quick after it has ran long enough to get good and warm.
/ Hydraulic problems #6
Actually the most temperature rise will be right at the piston. This is a great mess free troubleshooting method. As little as 5 degrees of temp rise as compared to the rest of the barrel has been 100% successful for me over many years.
2019 Kubota KX057-4 (A64126)
2019 Kubota...
2022 FORD F-750 SUPER DUTY DUMP TRUCK (A63276)
2022 FORD F-750...
Pallet Forks (A64127)
KMC 12 Row Rip Strip Till (A64126)
KMC 12 Row Rip...
2017 CHEVROLET SILVERADO 2500HD (A65643)
2017 CHEVROLET...
2007 Freightliner FLD120 (A62679)
2007 Freightliner...
