hydraulic leak
/ hydraulic leak #1
chugger172
I've developed a hydraulic pinhole leak on 7/8 OD tubing on my Ford 4500 TLB. So far, I've been unable to loosen the flare fittings to pull the piece out. Do they make a repair clamp that would work in the situation?
/ hydraulic leak
I just can't loosen the flare fittings, 50+ year old tractor. Looking for a band-aid
/ hydraulic leak #4
Did you try heat on the fitting? Usually corrosion bonds the nut to the threads.
/ hydraulic leak #5
A quality flareless fitting may be a good repair as it would allowed a small amount of tubing to be removed when installing a union type compression a "bulk head union " will allow for a bit more tubing to be removed.
2018 MACK PINNACLE (A67714)
2018 MACK PINNACLE...
PORTA POTTY (A68842)
1995 CHEVROLET KODIAK C7500(INOPERABLE) (A67714)
1995 CHEVROLET...
2019 Westinghouse WSTBT1503 Wireless Speaker (A61574)
2019 Westinghouse...
MAHINDRA 2538 TRACTOR (A65057)
MAHINDRA 2538...
Unused 2022 Land Pride 1006NT 10ft. Pull Behind Grain Drill Tractor Attachment (A66734)
Unused 2022 Land...
