hydraulic leak
/ hydraulic leak #1
chugger172
I've developed a hydraulic pinhole leak on 7/8 OD tubing on my Ford 4500 TLB. So far, I've been unable to loosen the flare fittings to pull the piece out. Do they make a repair clamp that would work in the situation?
/ hydraulic leak
I just can't loosen the flare fittings, 50+ year old tractor. Looking for a band-aid
/ hydraulic leak #4
Did you try heat on the fitting? Usually corrosion bonds the nut to the threads.
/ hydraulic leak #5
A quality flareless fitting may be a good repair as it would allowed a small amount of tubing to be removed when installing a union type compression a "bulk head union " will allow for a bit more tubing to be removed.
