hydraulic leak
/ hydraulic leak #1
chugger172
I've developed a hydraulic pinhole leak on 7/8 OD tubing on my Ford 4500 TLB. So far, I've been unable to loosen the flare fittings to pull the piece out. Do they make a repair clamp that would work in the situation?
/ hydraulic leak
I just can't loosen the flare fittings, 50+ year old tractor. Looking for a band-aid
/ hydraulic leak #4
Did you try heat on the fitting? Usually corrosion bonds the nut to the threads.
/ hydraulic leak #5
A quality flareless fitting may be a good repair as it would allowed a small amount of tubing to be removed when installing a union type compression a "bulk head union " will allow for a bit more tubing to be removed.
2016 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A64194)
2016 Chevrolet...
WESTENDORF 12' LANDSCAPER BOX GRADER (A63291)
WESTENDORF 12'...
2008 Ford E-450 Super Duty Ambulance (A61573)
2008 Ford E-450...
EZ-GO SHUTTLE 2X2 TXT GAS GOLF CART (A63276)
EZ-GO SHUTTLE 2X2...
2016 TEXT 26ft T/A Dovetail Flatbed Equipment Trailer (A59230)
2016 TEXT 26ft T/A...
2019 FREIGHTLINER M2 106 4X2 S/A 26FT  BOX TRUCK (A59912)
2019 FREIGHTLINER...
