Hydraulic issues; ditch bank flail
   / Hydraulic issues; ditch bank flail #1
mwark
Maine
L6060
This weekend I put together my new ditch bank flail mower. DB Flail
I'm having an issue with the hydraulics "fading". The tip of the cutter, furthest from the tractor, is constantly dropping. After only an hour of cutting it's clear that this condition is not going to be acceptable.
Any ideas? Maybe a defective cylinder?
Thanks!
   / Hydraulic issues; ditch bank flail #2
Do you mean the tilt function? Unless you have a lock valve on the cylinder, you will get some leakdown.
How are you using your mower?
I run my ditch bank with the tilt in float most of the time so it will follow the contour of the ground.
If I have to hold it at a certain position, I will need to make small adjustments from time to time.
This control will move the flail from +90 degrees to- 50. I’m finding that every 90 seconds or so I need to adjust. Even on level ground I have tweak it constantly.
   / Hydraulic issues; ditch bank flail #4
Mine has a "lock" or pilot operated check valve on the tilt cylinder.
In the close up picture you can see the lock valve, also where the lower pin (the rod end) goes to the deck there is a slot unless I'm carrying the deck I try to keep that pin centered in the slot.
   / Hydraulic issues; ditch bank flail #5
That's common due to the leverage on the cylinder, unless you have a lock valve.
Are you running it vertical? If you're just using it like a normal mower, it should ride on the roller and the front supported by the 3pt. I run my valve in float.
   / Hydraulic issues; ditch bank flail #6
Yep, that cutter is for use with a float capable valve and ride on the roller. Without the lock valve, they tend to droop. I have the BCRM-155 similar to the green one above.
   / Hydraulic issues; ditch bank flail #7
Just a quick add if your cylinder has the lock valve, float on the remote will not work. You would need to trim it to keep the pin roughly centered in the slot.
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
2025 JMR Tree Boom Skid Steer Attachment (A53421)
2025 JMR Tree Boom...
UNUSED SWICT 60" QUICK ATTACH BUCKET (A54757)
UNUSED SWICT 60"...
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
40ft 6-Door Shipping Container (A52377)
40ft 6-Door...
