Hydraulic filter Ford 1200 tractor
/ Hydraulic filter Ford 1200 tractor #1
JKELLEY26
Ford 1200
I just purchased a 1980 Ford model 1200 tractor with a Ford 768A loader. I would like to change the hydraulic oil and filter but I can't find a part number for the filter. Hate to put new oil in and not change the filter. Does anyone know what filter it takes? It is a cartridge filter, not a spin on. I have the operator's manual but it doesn't show part numbers for any of the filters.
Cheers
Jkelley26
/ Hydraulic filter Ford 1200 tractor #3
I’m remembering those to be a washable metal screen.
/ Hydraulic filter Ford 1200 tractor #4
yes , joecdeere is correct. i have a ford 1300 which is basically the same tractor and the hydraulic filter is a reusable metal screen. i just wash mine in gas, blow a little air thru it and let it dry good. reinstall and you will be good to go.
Thank you, it is a screen
BTW None of the NAPA parts seville009 recomended are correct
/ Hydraulic filter Ford 1200 tractor #6
glad it worked out for you. keep her running, handy little tractors. i recommend you never use starting fluid in it, i have heard of broken crankshafts in these tractors linked to the use of either (starting fluid)
TWO PALLETS OF HYD TANK, V8 ENGINE BLOCK/PARTS (A68842)
TWO PALLETS OF HYD...
2017 Ford Explorer SUV (A66738)
2017 Ford Explorer...
CATERPILLAR ENGINE (A67714)
CATERPILLAR ENGINE...
2016 WIRTGEN W150CFI MILLING MACHINE (A65056)
2016 WIRTGEN...
2018 CHEVROLET TAHOE (A66091)
2018 CHEVROLET...
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A59914)
2020 KENWORTH T680...
