Hydraulic filter Ford 1200 tractor
   / Hydraulic filter Ford 1200 tractor #1
JKELLEY26
Ford 1200
I just purchased a 1980 Ford model 1200 tractor with a Ford 768A loader. I would like to change the hydraulic oil and filter but I can't find a part number for the filter. Hate to put new oil in and not change the filter. Does anyone know what filter it takes? It is a cartridge filter, not a spin on. I have the operator's manual but it doesn't show part numbers for any of the filters.
Cheers
Jkelley26
   / Hydraulic filter Ford 1200 tractor #3
I’m remembering those to be a washable metal screen.
   / Hydraulic filter Ford 1200 tractor #4
yes , joecdeere is correct. i have a ford 1300 which is basically the same tractor and the hydraulic filter is a reusable metal screen. i just wash mine in gas, blow a little air thru it and let it dry good. reinstall and you will be good to go.
Thank you, it is a screen
BTW None of the NAPA parts seville009 recomended are correct
   / Hydraulic filter Ford 1200 tractor #6
glad it worked out for you. keep her running, handy little tractors. i recommend you never use starting fluid in it, i have heard of broken crankshafts in these tractors linked to the use of either (starting fluid)
2000 Freightliner FL70, 5.9 Cummins (A52384)
2000 Freightliner...
UNUSED GREAT BEAR FORKLIFT JIB (A51248)
UNUSED GREAT BEAR...
Rock wood travel trailer (A51694)
Rock wood travel...
UNUSED FUTURE FT1000J SMOOTH DOUBLE DRUM ROLLER (A51247)
UNUSED FUTURE...
2019 JOHN DEERE R4023 LOT IDENTIFIER 243 (A53084)
2019 JOHN DEERE...
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A52472)
2013 XLR...
