Rotary Cutter howse model 500 bush hog
/ howse model 500 bush hog #1
jmt1271
Platinum Member
MO
Kubota L2501
I am looking for a 5-6 foot bushhog. A friends dad has a Howse model 500 5 ft. From what I can tell it is an economy or light duty mower. I dont cut a whole lot but want something that wont require constant maintenance and will last a while. It is in average condition for a 4-5 yr old mower and he wants $450. What do you think of this make and model and the price?
thanks,
/ howse model 500 bush hog #3
That's a decent economy mower. I'd check the gearbox for leaks and see if any water in gearbox oil. Check out the stump jumper, blades, and bottom shaft. I'd also change the gear oil in it regardless of condition, and give it a good greasing.
If everything checks OK and it'll cut what you need, I'd say that's not a bad price. New ones around here run $600-700, depending on who'll cut you a deal.
If you need parts, you'll have to get Howse parts. A good local dealer is a lot better than trying to order straight from Howse Implement.
My dad has one he bought new 3 or 4 years ago and hasn't had any problems. I think he paid about $550 for his then.
/ howse model 500 bush hog #4
thanks,
Seems a little expensive to me, you can get a new one for $150 more. Unless it is in impeccable condition, I would pass.
/ howse model 500 bush hog #5
Where you buying new 5' howse ( or kk ) mowers for 550. They are at least 600+ in my neck of the woods.
I bought a KK from TSC in 2000.. it was 500$ then..
soundguy
/ howse model 500 bush hog #6
It was bought at the Buckatunna feed store in Buckatunna, MS. They are currently out of business.
Time marches on and prices go up Soundguy.:)
1999 Yamaha 350 Big Bear 4-Wheeler (A66408)
1999 Yamaha 350...
New 50Pc Equipment Key Set (A65579)
New 50Pc Equipment...
Kubota MX6000 HST Tractor with Loader (A65579)
Kubota MX6000 HST...
2011 GALYEAN 130BBL (A65643)
2011 GALYEAN...
2012 FREIGHTLINER M2 (A65643)
2012 FREIGHTLINER...
2025 Auger Bit Skid Steer Attachment (A64553)
2025 Auger Bit...
