How to Replace Kioti CK30 Headlamp
   / How to Replace Kioti CK30 Headlamp #1
hiker88
Bronze Member
belgrade, maine
none
Owners manual says to "remove the bulb from the housing body" or something like that but not much else.
What's the trick guys? Do you twist the back end of the housing body from under the hood or pry it back and forth? My tractor is too good to me for me to break it doing something silly!
Appreciate the help.
   / How to Replace Kioti CK30 Headlamp #2
What I would try is leftie loosely rightie tightly , it should pop right out.
DevilDog
Is that a guess or are you sure? I tried that but stopped because it seemed to be taking a lot more force than when I change a bulb in a car.
I'm all set thanks. Pry of the black rubber cover, and then it works just like an auto with the metal spring clip.
2003 Pierce 75ft Ladder Fire Rescue Truck (A55852)
2003 Pierce 75ft...
John Deere Metal Truck (A57454)
John Deere Metal...
2007 Ford F-450 Chip Dump Truck, VIN # 1FDXF47P97EB35140 (A57453)
2007 Ford F-450...
John Deere 5055E (A53317)
John Deere 5055E...
Case Axial-Flow Combine Wheels NO RESERVE (A56436)
Case Axial-Flow...
2021 Deere 333G (A53317)
2021 Deere 333G...
