How to Replace Kioti CK30 Headlamp
   / How to Replace Kioti CK30 Headlamp #1
hiker88
belgrade, maine
none
Owners manual says to "remove the bulb from the housing body" or something like that but not much else.
What's the trick guys? Do you twist the back end of the housing body from under the hood or pry it back and forth? My tractor is too good to me for me to break it doing something silly!
Appreciate the help.
   / How to Replace Kioti CK30 Headlamp #2
What I would try is leftie loosely rightie tightly , it should pop right out.
DevilDog
Is that a guess or are you sure? I tried that but stopped because it seemed to be taking a lot more force than when I change a bulb in a car.
I'm all set thanks. Pry of the black rubber cover, and then it works just like an auto with the metal spring clip.
skeleton / rock bucket (A56857)
skeleton / rock...
MARATHON 76KW GENERATOR (A58214)
MARATHON 76KW...
2022 Ram 2500 4x4 Crew Cab Pickup Truck (A55973)
2022 Ram 2500 4x4...
2008 FORD F-750 SUPER DUTY (A58214)
2008 FORD F-750...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A52709)
KNOW BEFORE YOU...
2005 Peterbilt 387 with Wet Kit (A56435)
2005 Peterbilt 387...
