How to Replace Kioti CK30 Headlamp
   / How to Replace Kioti CK30 Headlamp #1
hiker88
belgrade, maine
none
Owners manual says to "remove the bulb from the housing body" or something like that but not much else.
What's the trick guys? Do you twist the back end of the housing body from under the hood or pry it back and forth? My tractor is too good to me for me to break it doing something silly!
Appreciate the help.
   / How to Replace Kioti CK30 Headlamp #2
What I would try is leftie loosely rightie tightly , it should pop right out.
DevilDog
Is that a guess or are you sure? I tried that but stopped because it seemed to be taking a lot more force than when I change a bulb in a car.
I'm all set thanks. Pry of the black rubber cover, and then it works just like an auto with the metal spring clip.
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
SAFETY BOX FOR FORKLIFT (A52708)
SAFETY BOX FOR...
2016 New Holland Boomer 47 4WD 45HP Loader Utility Tractor with Bush Hog BH16-2 (A55787)
2016 New Holland...
2025 BrushFox HD-78STD 78in Rotary Brush Cutter Skid Steer Attachment (A56857)
2025 BrushFox...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A58374)
KNOW BEFORE YOU...
16 BLADE DISC HARROW (A52708)
16 BLADE DISC...
