How to fix this crack
/ How to fix this crack #21
Just a Weld, no matter how you prep it may not be enough if you don't stop the crack from spreading onward. cast, Steel, Aluminum or what ever. As long as you are tearing it down it wont hurt to drill a hole at the ends of the crack to stop them in their tracks.. Nip it now and don't look back.
/ How to fix this crack #22
First, get it steam cleaned all over before you do it. Then grind, grind grind. I wouldn't worry about the oil that much in the tank. It isn't that volatile. But for safety's sake, you could flood the tank with some pure CO2 or argon and keep a little bit running in while welding.
A plate over the corner like shown would be a good idea, just round the edges of the triangle. Also, weld one inside the frame too (or more). It looks like the crack continues onto the inside and underneath side of the weld possibly.
Get some fresh out of the can 7018 for this and get them hot before using. You should be able to burn the flat area in at 130 amps or so with ease. MIrror what you do on the other side as well before you finish too.
OK, so the consensus is it might be reparable by an idiot like me. THats good.
So my engineering question. Why do you use an oval instead of a square for a binding plate?
Second, my neighbor whom I do trust wanted me to use angle iron along the edge (maybe 2.5 feet of it) to "rigidize" that side and then the other. But it soundes like this would be a bad idea structurally. Why?
Finally, the fishplate (that is what you all it, right? an oval is a fishplate)? What thickness would be prescribed?
/ How to fix this crack #24
Stress "accumulates" at sharp corners and sharp corners are the classic spot to find fractures. Rounding the edges distributes the forces so they don't concentrate.
I'm not sure the angle iron idea would have been bad before there was a crack but it won't solve the crack issue.
There are probably engineers here who can tell you what thickness the plate should be. I note that such plates on new equipment is usually about the same gauge thickness as the surrounding metal.
Also, Drilling. I saw this done on Aircraft Aluminum. Is it something I should do here or will the fishplate stop the cracking? If I do drill do I weld the drill hole?
/ How to fix this crack #26
Standard recommendation is to drill the end of the crack and then weld the hole closed along with the V'd out crack.
/ How to fix this crack #27
I have always been told a fish plate should be the same thickness as the material it is being welded to.
When drilling holes at the end of a crack. Start the weld in the center of the crack, and weld towards the hole. Feather / grind down the start of that weld. And then weld towards the other hole.
/ How to fix this crack #28
I don't think a "fish" plate will help, unless you're hungry.
A flitch plate could be very helpful though. ;)
/ How to fix this crack #29
/ How to fix this crack #30
I have always been told a fish plate should be the same thickness as the material it is being welded to. When drilling holes at the end of a crack. Start the weld in the center of the crack, and weld towards the hole. Feather / grind down the start of that weld. And then weld towards the other hole.
That makes sense but what is the rationale for welding from center out? Is that just a general point or specific to crack repair?
And one more thing on the Fish (Flitch) plate - what is the proper length and width. I assume a few inches on each side and nearly the whole width of the side of the tub (so a 3x7 or so)
/ How to fix this crack #32
Flitch plates?? That would be a new one for me. I've added fishplates onto center sill's of RR cars. I'll attach a photo of a properly installed one onto a auto frame.
OK, and one more question based on the picture, do I need to do center holes (cutouts) on my fishplate? It seems too small for it but I get it adds structural integrity.
/ How to fix this crack #36
If your plate is just 3x7 you could add slot shaped holes in the the center, instead of the round ones. If your plate goes up against a frame member or corner, then it should be a different style cut plate. Here is pictures of a design that might work for you... Do note, in the top design, its suppose to be welded 100%. Not so in the lower one.
Does this help??????
/ How to fix this crack #37
I'm at a real disadvantage trying to help in these situation:eek::eek:. The majority of my welding was done off engineered blueprints. Not really up for discussion with blueprints. You either do as the print says, or the company will find someone else to do it.:eek:
/ How to fix this crack #38
Well gee, maybe I'm at an advantage here. I spent 20 years in the energy business doing mostly repairs.
/ How to fix this crack #39
I've done very little repair work. I built bridges, container ship docks for a living. I did work for 3-years in a fab shop building nuclear waste tanks. Here again, all off blueprints.
/ How to fix this crack #40
In reference to the auto frame repaired with a fishplate, I note that a long rectangular plate is welded to the top of the frame by welding through holes drilled in the plate. What's that type of weld called (when you fill up a hole to connect plate to base rather than weld edges)?
2003 VOLVO G720B MOTOR GRADER (A66091)
2003 VOLVO G720B...
2022 Power Screen Phoenix 3300 Tri-Axle Trommel Screener (A64194)
2022 Power Screen...
2022 EZ-GO ELITE...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
Landhonor Quick Attach Screening Bucket (A66408)
Landhonor Quick...
2007 Down to Earth Equipment Trailer (A65563)
2007 Down to Earth...
