How to find septic lines?
/ How to find septic lines? #21
Called dowsing and I use it all the time, works great..
Me to, I have been doing it since age 8 and it works great. If you have a known line somewhere, practice over that to get a feel for how the wire moves in your hand. The key IMO is how you hold the wire, so it only contacts two opposing points in your hand. One is the flat on the heel of your hand, and the other is the flat on the tip of your index finger. It can be a little akward to hold but this hold gives you a low drag pivot point so the wire will swing easilly by, I believe the disturbed magnetic field caused by the buried object. I can take a picture of how to hold the wire properly if you want.
Try it, you have nothing to loose, and you can easilly confirm your findings with a rod pushed into the ground to physically locate the pipe.
/ How to find septic lines? #22
Did this tell you how deep any of it was burried?
I know my BIL's line locator will tell you roughly how deep a line is if it is using "active" mode. That is, if there's a tracer wire on the buried utility that the unit itself powers. Dunno if 'active' mode is the correct term, sorry....
-Jer.
/ How to find septic lines? #23
Witch it. RonMar is right on. It works on plastic or metal pipe. Practice where you know the location of a buried pipe. I use this method often with good results.It's good idea to get utitilie locates before you dig. In my area you just call 811.
good luck
/ How to find septic lines? #24
I know many don't believe in this, but many years ago, my uncle - a life-long farmer showed me how to use coat hanger to find electric and water/sewer lines.
Take a wire coat hanger. Cut off the twisty part & the hook. Cut the rest of it in half so that you have 2 equal halves. Straighten each piece. Then, put a 90deg bend about 4-5" on each piece.
Make a very loose fist, like you would hold a stick straight up in the air. Place 1 of the hanger pieces in each hand. Make sure they can move freely.
Slowly walk towards the direction where you think the lines are. When you get close, they will start to cross. Make a mark in the dirt when they are pointing directly at each other. Then, do the same thing from the opposite direction. Depending on how deep the line is, you should end up with marks betweed 2 & 4 feet apart. The line is somewhere between the 2.
I never would have believe it until he showed me, AND I did it. It really works. Of course, Ms Utility, etc are better, but how much fun is knowing EXACTLY where the pipes are :)
I always find every drain, sewer, and line using this technique. It's called "witching".
Once, when the guys came with an auger on a bobcat, to bore holes for a large barn, I found, and marked things all over the area. There were so many lines it looked like there was no way they all could really be there. They all were, trenching for the downspouts later, they hit every thing I marked; a sewer line to septic, 2 overflows, 2 power lines, and some drain tile. You can't tell what it is, but you can tell where it is.
/ How to find septic lines? #25
On some of the houses that I've worked on, you can find an odd colored brick where the sewer line is. Other times, I have to do a little digging outside the bathroom wall to find the drain line. Then I'll probe it if I can, but in the summer, the ground can be too hard for a probe to work. I've dug up the line and followed it to the tank. In those cased, it wasn't very far from the house. There is no advantage to setting the tank very far from the house, so the ones that I've found have been fairly close.
I didn't have a metal detector then, but saw them used by others. The septic pump guy has one and he can find a tank pretty quickly. The tank might be concrete, but the lids are always metal.
Once you find the the tank, it coudl be even more challenging to find the leach field. Usually it's common sense on where it was put. The trees will dictate it's location allot of the time. You can't put a field in the middle of a bunch of trees. Depenind on the soil and land available, it might be several lines going in any direction.
I found one this past summer that went about 60 feet from the tank. It went out straight, took a 45 turn to go around a tree, then ten feet later, it took another 45 turn, and then went to where the field was.
Lucky I found it, because we were going to pour a pad there for an RV. The owner of the land had it all backwards and to be honest, I thought he was right, but when I found the tank, there was a line leaving it that went in the wrong direction. After digging it up out of curiosity and a certain level of not being sure where the leach field was, I found it.
Never assume anything.
Eddie
/ How to find septic lines? #26
we use a Ridgid camera with transmitter & locator for our jobs,
Gives a video inspection of the pipe if there any problems
/ How to find septic lines? #27
I use coper welding rods for this. Works for me!
/ How to find septic lines? #28
Just have the septic tank pumped! Heck the guy will come find the tank and pump it out for you, then have him show you where the line is.........
/ How to find septic lines? #29
An older gentleman told my Father where to dig his well in the 1960's by dowsing. Struck water at 500' or so and has been providing water since then.
Once your find your septic lines, plant daffodils to mark the lines and the box corners.
You can make those rods bend any way you want. I purchased a professional set made very well. they were shiny brass looking, bent to the correct angle, and the handles were inside a small PVC pipe to eliminate friction, with metals balls on the end, I tricked many people that I could witch for water. Here in Florida, you will find water almost anywhere you did.
There is no scientific reason that this works with any success. It is just pure luck and knowing something about topography. and observation. What so you think would happen to those rods held level, out in a boat, on water. You think those rods might just spin uncontrollable Ok smart guys, why did the older generation use wood, and a particular wood, and it had to have a certain shape, like a { Y }, and when you found water, the the stick would bend almost straight down. If this part is true, why are the trees not bending their branches down pointing to water, but maybe they are. Just find the tree that is bending down, and you have found water. Now it is brass, steel, copper, coat hangers, what is next, plastic. How do you think it works, by lines of force, then why use wood. Do you think the lines of force might be concentrated inside metal pipe. Does it work with PVC pipe? Someone once told me the principle works on faith, got to have great faith though. Sometime back, someone offered a large reward for someone to find water with a reasonable accuracy, and it appears that no one has collected yet. I have faith, but not in every thing.
Believe what you want to believe, that is just life.
/ How to find septic lines? #30
A bit off topic but my uncle always buries some caution tape about a foot or two underground when backfilling trenches. That way, later if you happen to be digging you hit the tape and it's a warning that there is something buried deeper. I wish he told me this before I put in the septic field, buried the wires and water line to the barn!! LOL
/ How to find septic lines? #31
I fully understand your skepticism, I too felt this way once. You don't find six different lines, you did not know were there, in a 30' x 40' area, with luck.
I have never seen the Y shaped tree stick demonstrated, and have no idea if it worked.
I have seen many times, and personally used the wire rods with a very high degree of success, (nearly 100%). A much higher degree than "chance" could possibly ever achieve.
Make a set up, and walk through your house with them. After learning to keep your your hands level, and slightly lose, so they can swing, you will locate every pipe and duct under your floor, which you can, (especially if you had a basement, I know in Fla. it's not common), visually verify.
If you know where lines are in your yard, use some one who has no idea what is going on like a female, or child, to do the witching out there. They will locate them.
Another way, is to go where underground utilities have been marked for digging, and test there.
I'm no fool, if this was not possible, I would not bother trying to convince you it was.
Disbelieve what you want, but please don't do it on the basis of your assumptions.
/ How to find septic lines? #32
I've used a probing rod many times to locate our irrigation system lines, 3-4 feet deep. we had about a mile of 4" pvc pipe with 30 neighbors tapped into it. the trick to make the rod work is the 'tip'. i used 4' piece of cold rolled rod (3/8) with a t-handle of 3/4 pipe welded to the top. for the tip, weld a 1/2 ball bearing on. it must be slightly larger diameter than the rod. that way your basically pushing a ball bearing into the ground with out having to overcome the friction of the rod. works great!
/ How to find septic lines? #33
This is code here in MN at least for buried electrical lines.
/ How to find septic lines? #34
'Divining' is certainly interesting. Our well was found that way when I was a kid and I spent days 'witching' our property.
How could it possibly work? Did you know gravity is not a constant? If you go to India you will weigh about 1% less than you do in the US. The lower the elevation, the less gravity there is. Perhaps 'divining' rods react to local variations in gravity cause by local variations in ground density (water is less dense than earth)?
Who knows but it is a lot of fun, grab some rods and walk around.
/ How to find septic lines? #35
I don't know if there is a known explanation for this. But, I do know there are more things science does not know, than things we do know.
For example, we don't know what most of the universe is made of, the dark matter as its called, we can't see it. We know its there because we see it effecting things we can't see. But, we don't yet know what it is.
Actually we STILL don't know why aspirin works. Does that matter when you need it?
People who refuse to believe anything that can't be proven to them, brought us the flat earth society. We now know how that one turned out too.
/ How to find septic lines? #36
Eddie
Hey Eddie, Just to make it clear for people in diff. parts of the country. Out here NW Arizona and S. Nevada all the lids I have seen that "come with the tank" are concrete. You can buy lift rings and a metal lid for extra bucks. These are usually used if the tank (Not the leach feild)will have concrete poured over it.
Seems to me a burried metal lid would rust away.
Terry
/ How to find septic lines? #37
I forgot to put the caution tape in this trench ;but I'm not digging it back out to install it.
Tilling the dirt with the used BX1500 to make it finer for back filling the trench for the electric line.
Finished trench.
/ How to find septic lines? #38
I am usually part of the "flat earth society" and did not belive in divining rods until I was shown it work. Then, after finding the water line that was buried decades before, on property my unkle had never seen before, in a part of the state he had never visited, I was a skeptic. Then, when he showed me how to make it work so I could do it myself, I was a believer.
/ How to find septic lines? #39
There seems to be believers and non believers in the subject of WITCHERY, DOWSING, AND DIVINING, using all kinds of material . This so called technique from finding water under ground has been integrated to finding just about anything, such as septic lines, septic tanks, water pipes, sprinkler lines. Where will it go next, stand over a prone human body, and find some illness, etc. It has been said that only certain people have the skill, or implied gift. Supposedly the best guy that could find water by Dowsing/Divining, could only do it using a peach root not more than 3 days old. and other people used different twigs , fresh cut , in a { Y } shape and when water was found, the single branch of the witching stick would start twitching and bend either straight down, or up. supposedly following the lines of force. It was also said the best people at Dowsing would not take any money for displaying the gift that they had. I guess I don't have the belief to make it work, although I have tried many times. I would love to see a person with the so called skill, find all my sprinkler lines, septic lines, and gas lines, and electric lines, and then make a map showing all the things found. How did this technique gravitate from a forked twig into welding rods. I have read many articles and tried the technique, but if this were a credible skill, then it should be taught. It should not be a mystery, and should have some understanding. My thoughts are, a forked twig is not going to bend in my hand, unless I force it to bend. I can also make thse metal rods point opposite of each other. It is really a neat trick, just twist your hands a little, and the stick will bend, and twist the other way, and it will bend up. Sorry guys, I just am not buying it. If anyone can repeat this Witchery, Dowsing, or Divining thingy, then you should be in the Witchery business and making lots of money.
/ How to find septic lines? #40
JJ, I can understand your skepticism, no matter which direction a stick points in Florida it's pointing at water! :D MikeD74T
