How much winch is enough?
   / How much winch is enough? #11
The solution, and I've have a winch on my trailer, 20+ years, and I haul junk. Use a 50' cable and double line it. That way, it's full power. Good battery. Use chain from pulley to tractor. That way you can shorten or adjust as needed. Works best if you use a short chain hooked on tractor in a loop around front axle. Then other long chain loops through axle chain and eye or hook on pulley. Those winch blocks at hobo frate are sold right beside the winches. And it helps greatly to have chain to tie tractor off when you're in the middle of winching, in case you need to let winch off and re-adjust your situation. Say you're almost to the top of ramps. I carry a 3 ton lever hoist just in case. It will load a tractor without any wheels on it, but I break out in a sweat every time I glance at it. So I keep it hidden. I have come alonged a two ton army truck with flats all around, up on a trailer. It was WW2 truck parked in mid 60's, and grown up in the jungle down here, and was complete.
HF winches are fine, they'll hang with the others. 5,000 double lined, should be fine with a rolling load. I've had a 5,000 and it did fine. Like I said, a shorter cable and a pulley will maximize everything. When you pull and front wheels break over the ramps, you can re adjust and connect pulley to short chain and pull onto trailer.
Keep some wheel chock blocks too. In case your trailer is facing down hill, and I always try to winch that way if I can. This is Arkansas and I don't live in the flat part. Just throw one in front of a wheel because tractor may roll up and hit the front, and you don't want that. Or your load may be too far forward, and you'll have to get it back rearward. So tie pulley at rear of tractor and single line to front of tractor and pull it back some. You can un load it that way also, if your trailer is down hill at your unload location.
I have three trucks with pto winches, flat beds with gin poles and rolling tail boards. Two 2 - 1/2 tons with cranes that you can set trusses on a house with. One 4wd 4 wheel steer rough terrain crane, 30,000 lb lift. A few service trucks with cranes. Its all just old things that still works. But, with a double line pulley, chains, and blocks, you should be just fine.
It's was a dangerous life growing up in the south. As a young boy, I prayed. I didn't pray for a wife, and I don't have one. I didn't pray for children, and I don't have any. I did pray to be old and die with all my fingers and toes, and I still have all of them. So I'll be the first to tell you, prayer has worked for me. See, I figured if I had my fingers and toes, I would have everything in between.
   / How much winch is enough? #12
Yikes! But don't do this. Wire through metal should have a grommet. 😵‍💫
   / How much winch is enough? #13
The thing is the other big winch companies don't publish duty cycles and just say to use your best judgement. What I am finding from the 4x4 sites is the duty cycle under full load on a Warn 12K winch is 30-60 seconds, as compared to the HF which is 45 seconds.
I have both, the Warn 12K and the HF 12K. My warn has thermo overload shutoff, if you run it too long under heavy load it will shut off and only spool out, the HF will keep going until it destroys itself. I've read of guys burning out the HF 12K.
I've winched with my Warn 12K for several minutes, over and over dragging a fully loaded (building supplies) 3/4 ton pu, some of the way dragging on the frame, through a long swamp in the Alaskan bush and not had it shutoff because it wasn't so hot it "tripped" the thermo, I wouldn't trust my HF to do the same thing, no way.
I also have other winches, 25,000, 9000, 5000, 3500, 2500 so I have an idea on what and how winches will pull...
I have seen several of the 2500 winches burn out and also just plain break, they are cheeep for a reason.
SR
   / How much winch is enough? #14
I would think a reasonable minimum would be the 9,000 lb model in my experience, roughly double the weight of the load to make it useful at any angle or winding depth.
Full size trucks averaging 6k or so use a 12k winch, and Tacoma/Ranger size trucks at 3-4.5k use a 9k winch
This is a 10,000 and we drag several logs at a time, pull out equipment, whatever. He should be fine with 5k and double line pulley. I would always have a pulley anyways. We made the fairlead. You can see the log loader in the background.
   / How much winch is enough? #15
I have an #8000 Warn. With a good battery I can pull a Blazer on with very low tires on a single line easy. No problem.
That is a good post but could you explain "double line it"? Do you mean run the cable through a snatch block attached to what you are winching and then attach the cable end hook back to the winch or beside it?
   / How much winch is enough? #19
Yep, it's a 10,000 winch then.
   / How much winch is enough? #20
Yes. Mechanical advantage, that is doubling the pull force. If you ran it through another block and back you’d quadruple it. Or you can get really fancy getting three to one advantages…but it’s a pain with cables.
2003 Ford Pressure Digger Truck (A55973)
2003 Ford Pressure...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A56436)
PENDING SELLER...
2018 DODGE RAM 2500 (A58214)
2018 DODGE RAM...
2019 Chevrolet Tahoe SUV (A56859)
2019 Chevrolet...
2012 TEX MEX TRAILER LOW BOY GOOSENECK (A58214)
2012 TEX MEX...
2014 Ram 2500 Pickup Truck (A55973)
2014 Ram 2500...
