How much can a John Deere 4440 pull?
   / How much can a John Deere 4440 pull? #1
Farmer28
John Deere 5410
So my question is this... Can a John Deere 4440 pull a Killbros 500 gravity wagon? (500 bushels). A: I know it depends on if its flat ground or going up a mountain, could it handle a terrain like rolling hills, nothing crazy. Gradually slopes, but generally flat. B: Transport grain from field to grain bins. Anyone have any experience with a John Deere 4440?
   / How much can a John Deere 4440 pull? #2
Weight of 500 bushels of what? Shelled corn would weigh about 28,000 lbs, and JD 4440 weighs about 12,000 lbs.. So would need some more weight added to the tractor??
Or brakes on the gravity wagon to help stop !! Some bad accidents have been known pulling a wagon loaded and trying to stop going down hill. Can get ugly real fast, resulting in a panic one-wheel braking, sliding, jack-knifing, then rolling the tractor over in the ditch. Don't ask how I know, as it happened to a neighbor farmers wife. The one rear wheel skidding quite a ways down the road, before piling up in the ditch. She survived.
   / How much can a John Deere 4440 pull? #3
John Deere 4440 Weight
Shipping11780 lbs
5343 kg
Operating13270 lbs
6019 kg
Ballasted15775 lbs
7155 kg
Is your JD4440 2-WD or 4-WD?
   / How much can a John Deere 4440 pull? #5
Yes a 4440 will pull a 500 bushel wagon. Like others have stated hills and stopping require some caution. We pulled 350 bushel full of corn with 5600 & 5000 Fords.
   / How much can a John Deere 4440 pull? #6
We have a 5610 Ford that weighs 13,600 empty. Yes, I weighed it. With tractor brakes I'd pull it. If you had brakes on the wagon, even better. Lock brake pedals together. Always remember, some people can mess up a soup sandwich. So you'll have to factor that in too. One person may do it all day, the next one will wipe out on the first trip.
   / How much can a John Deere 4440 pull? #7
5000 + #s of added ballast to shipping weight is A LOT OF added weight.
I agree with others that stated pulling 500 bushels is no problem but STOPPING that load is a totally different matter.
   / How much can a John Deere 4440 pull? #8
In the past, I've pulled a fully loaded tandem axle flat rack (repurposed sileage wagon) loaded with 10 layers of small square bales with my Honda 400 Foreman quad down the road. Stopping it in less than a football field length was another issue however. You can pull about anything with anything but stopping it can be an issue.
   / How much can a John Deere 4440 pull? #9
Kind of reminds me of the Ford commercial where they use a new electric F150 to pull 2 loaded car racks. What they don't show you is the car racks slamming into the back of the 150 and destroying it because while it can pull them, it cannot stop them. Duh.
   / How much can a John Deere 4440 pull? #10
I agree with others that stated pulling 500 bushels is no problem but STOPPING that load is a totally different matter.View attachment 766652
It's all in the weight. I had a neighbor pulling a 33' stock trailer jam packed with cattle, couldn't fit another one in it. He would come by in a short wheel base, regular cab, 4x4, Ford ranger, pulling that trailer in low range. We was pulling them cows and none of us even had a driver's license yet. Hauled square bales with a trailer and an old Chevy truck. Brakes wore slap out. Metal to metal. If you barely touched the pedal, front right tire locked up and skidded until we stopped, so we was always slow go with that rig.
But the 5610 does weigh that much. Filled 4 tires, belly pan, loader.
Hauled many loads of logs with a 3/4 ton regular cab. If it didn't weigh 50,000 pounds, we weren't loading enough on it. But, we quit that kind of hauling. We never got caught, but some other guys did, and we learned from them. It cost them $ 8,000.00 to go home.
Gravity wagon does have brakes on it. Ground is relatively flat the rolling 'hills' or slopes I'm talking about are all gradual and you can see over all the 'hills'
   / How much can a John Deere 4440 pull? #12
Is your JD4440 2-WD or 4-WD ?
Very limited tractor capability to brake a wagon on even a slight slope, if 2-WD.
   / How much can a John Deere 4440 pull? #14
You must have a "very thick belly pan" on that Ford tractor.
3x6 runners, cab and all are 3/8 thick tubing. Belly pan is 3/8" plate. We wanted weight.
   / How much can a John Deere 4440 pull? #15
3/8 plate weighs 15.3 per #s per sq foot so an 4 X 8 sheet weights 489.6#s belly pan plus the attaching frame/hardware. That still requires a lot for weight for liquid ballast & FEL to achieve 13,600 #s total weight.
2014 FORREST RIVER SALEM TRAVEL TRAILER (A58214)
2014 FORREST RIVER...
207270 (A52708)
207270 (A52708)
John Deere XUV825E (A61306)
John Deere XUV825E...
GUN BOX FOR TRUCK BED (A60432)
GUN BOX FOR TRUCK...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A59823)
2018 GENIE...
Rockport Mobile Command Center (A59230)
Rockport Mobile...
